1 - 2 of 2 Posts
My truck has 22x,xxx miles on it. I am getting the code for the turbo vane position not learned. Is this likely just the sensor or should I be looking to replace the turbo? Thanks in advance for your help!
Former GM Tech and parts
I think getting it diagnosed correctly will tell you which direction you need to go. My assumption from the description of the code would be it just needs a vane position sensor, and then reprogrammed. But proper diagnosis is key to not replacing more than what is needed
1 - 2 of 2 Posts
