1 - 10 of 10 Posts
i am just looking for a to the point answer on what size of a turbo i would need to make a twin setup utilizing the stock turbo as the primary and if the secondary turbo needs to be waste gated and what not
thanks
trans is being done before the summer weather arrives up here lol then the rest of the mods
most use a S400 turbo as tyler said. i have seen people use S471 up to S480 and some have gone much bigger on high HP setups. using a stock high pressure turbo though a S475 is probably your best bet
i have a buddy that runs a cummins and he said to look into a ht3b turbo. it is basically the same specs as the s471-s480 sizes with a 1.2 or 1.32 ar and it runs a t-6 housing as well. any thoughts??
DuramaxForum Veteran
Cummins guys use that turbo a lot. It is not much cheaper than an S474 and IIRC does not have the ETT that the S474 can have.
so the best turbo for a setup like this would be an s474 or s475 then??
Vendor
The S475 works well with the 1.32 ar exhaust housing like Durallymax mentioned.
1 - 10 of 10 Posts
