Guys running twins I want to do a 4 gauge pillar setup 2 of which will be analog boost and pyro and 2 digital but then again not sure.... If I do twins somepoint in my life I will probably want more boost gauges or a drive pressure gauge.... I know some of the digital gauges will do 2 readings at once but do they all plug into the ob port? So I guess I'm just lost and not sure what to do.........:help What are you fellas with twins monitoring while you are pimping the panty dropper down the street? Thanks for your input.
