1 - 1 of 1 Posts
:helpFor the second time in as many months my truck is throwing a U0101 code. As you can see in my signature I have EFI Live with a DPS 5 and a CTS screen.
The first time I replaced a 10 amp fuse in the drivers side dash fuse block. I am assuming this will fix the issue again, but want a better and longer lasting solution. I have searched the code here and found similar cases, but nothing spot on and nothing with solid suggestions of things to look for or at. But my truck runs and drives fine (have not tried the manual shift). When the truck throws the code the CTS screen also stops working when the key is in the "on" position.
Any help appreciated. If nothing comes of this post I'll be taking the shifter apart in the coming days to look for lose or broken wires.
1 - 1 of 1 Posts
