1 - 20 of 56 Posts
I now have 6,000 miles on my 2017 Duramax. Twice now I have had the 30% DEF caution come on and at the same time have had DEF mileage remaining warnings showing only 130 miles and 160 miles. On both occasions, the DEF level went from 30% to reading "Low" after about 50 miles, along with the caution that says something like "DEF Low - engine will soon be speed limited". In my 2015 Duramax, 30% DEF corresponded to approx 1000 miles remaining, now it seems to correspond to about 150 miles remaining. Also, assuming that the DEF tank was full when I got the truck and again full after a service where they said they topped up the DEF tank, both times I got the 30% DEF light after about 1000 miles of towing a 7500 lb travel trailer. I have now used 4 tanks of DEF in 6,000 miles (most of those miles towing the 7500lb travel trailer)
Is this normal? Anyone else seeing this behavior? It sure seems like my truck is burning through DEF at a rapid pace.
P.S. The first time this happened, I had to find DEF in the middle of nowhere, Montana, and filled up with some unknown brand of DEF. Shortly after I got a CEL The code was P0821. This happened again 3000 miles later - same code P0821. The fix, applied after the second incident, according to Chevy dealer was to reprogram the TCM and ECM. No CELs since that fix in around 1000 miles of towing.
You assuming they ever filled the tank is the issue.
Sent from my SAMSUNG-SM-N930A using Tapatalk
No, even if they didn't fill the tank, having the 30% DEF caution come on at only around 130 miles until "DEF Low" is the real issue. Shouldn't the 30% DEF remaining light come on with around 1000 miles left until DEF is empty. Also, going from 30% DEF to "DEF LOW" in less than 50 miles is also an issue (I think). How many miles of DEF remaining are others seeing when the 30% DEF caution comes on? How many miles between 30% DEF and DEF Low warnings?
Note - both times this happened I was towing 7500 lb travel trailer
I have seen other reports of very heavy DEF usage when towing with the L5P, maybe that is one reason for the increase in DEF capacity in 2017 to 7 gallons. The diesel supplement doesn't make a lot of sense either because it states when the 1,000 mile warning appears approximately 3.8 gallons are needed to fill so unless the warning is VERY conservative the 3.2 gallons in the tank at the 1,000 mile warning isn't expected to last very long. According to my math the manual indicates the 1,000 mile warning comes on with about 45% remaining in the tank (3.2 gallons left out of the original 7).
There is probably a way to make the warnings/level readout more asinine and less useful than current but it would take a room full of consultants to do so. With all of the electronic horsepower currently available a simple and fairly accurate readout of DEF tank fill level and the ability to use the trip computer to display average DEF consumption per 100 miles would make it a lot easier on owners to plan ahead.
I am pretty set on ordering a 2018 Denali to replace my 2006 Sierra SLT but stuff like this makes me sometimes wonder if I am about to make a mistake. The L5P equipped Denali would be my third Dmax powered Sierra and the first two have treated me very well.
i have seen other reports of very heavy def usage when towing with the l5p, maybe that is one reason for the increase in def capacity in 2017 to 7 gallons. The diesel supplement doesn't make a lot of sense either because it states when the 1,000 mile warning appears approximately 3.8 gallons are needed to fill so unless the warning is very conservative the 3.2 gallons in the tank at the 1,000 mile warning isn't expected to last very long. According to my math the manual indicates the 1,000 mile warning comes on with about 45% remaining in the tank (3.2 gallons left out of the original 7).
There is probably a way to make the warnings/level readout more asinine and less useful than current but it would take a room full of consultants to do so. With all of the electronic horsepower currently available a simple and fairly accurate readout of def tank fill level and the ability to use the trip computer to display average def consumption per 100 miles would make it a lot easier on owners to plan ahead.
i am pretty set on ordering a 2018 denali to replace my 2006 sierra slt but stuff like this makes me sometimes wonder if i am about to make a mistake. the l5p equipped denali would be my third dmax powered sierra and the first two have treated me very well.
^^^ x2
Dealer probably never filled it.. I know mine never did and I've been putting in 5 gallons every 3 or 4k miles it seems like.. And mine will go from 30% to low in a pretty short time also but I don't really watch that much.. Generally when I first see the message come on when it's just below a thousand mile range I'll just fill it up again..
Reactions: barryusa
Monitor the DEF yourself. Do not rely on the dealer. My L5P has used 13 gallons in 8,000 miles. In my opinion is too much. No weird messages. The one time I let it get low I saw a 3xx Miles to go message. There is no denying the DEF gauge sucks.
Fill the DEF and fuel tank... with fresh juice right when the DEF warning pops. Write down the mileage. Observe as you "daily drive". Report.
Our L5P with 1800 highway miles, idled in our drive for about 20 minutes then messaged me to drive until message went away. Seems excessive to me that an idle cannot be done... unless this is an engineering punishment for idling too long and should shut it off.
DEF fluid lasted about 1600 miles from dealer delivery. Refill did NOT take 7 gallons...just one jug... which I found interesting... yet the power and speed occurred before I could refill. Next long trip I will carry a jug or perhaps 2..
I believe the message you received was from inconvenient timing; the truck was due for a regen at the time you decided to idle it.
I hope that Edge has their Insight gauge display updated to show soot grams with the L5P before I order my new Denali because it would be very useful to know when the truck is approaching the need to regen so that I can plan my driving accordingly. And being able to force an active regen when soot loading is approaching the point where a regen is automatically triggered would also be valuable so that it could be done while on a normal highway run.
I ONLY tow with my truck and I average about 750 miles a gallon of Def. This is a close guess. The dealership if you look at the original PDI paperwork was ONLY supposed to fill the tank with up to 2.5 gallons. Some people got lucky and there dealership filled it for them. The New L5P uses about 15% more Def than my LMM truck and this is due to more stringent EPA standards.
I went just over 5k mi (4k "daily driving", and 1000 towing) before I got the low DEF message. filled it up and got the message again around 8k (all towing), seems to me it's tied pretty closely to fuel consumption, but that's just a "guess".
My dealership never filled mine so i got a DEF low message with like 500 miles on the truck. they filled it, and now currently have 4100 on the same def tank. doesnt seem to be using it at an alarming rate yet.
No need to guess.
GM published documents when the LML was released that indicated def consumption should 1.25 or 1.5% of fuel usage.
So 1.5 gal of DEF per 100 gallons of fuel.
(No reason to suspect there is any change for the L5P)
The increased cylinder pressure in the l5p which in turn is more nox creation... so more Def is needed
Sent from my SM-G903W using Tapatalk
I am confused.. I thought the regen was off the pressure difference (I.e. ; filter dirty / clean status..)... and the NOX sensors verify the levels. Please elaborate...
When I had truck a few days, I ADDED 2.5 gallons which didn't top off truck.
Today around 3000 miles, I got the "25%" warning...and I added 5 gallons. There was no remaining or overflow. I am going to speculate it is "full" but I may buy another jug to ensure we are "full" then verify use.
Going to make a 300 mile pull to the Corpus Christi area with our 34' tomorrow... Shall see..
The DPF collects soot and then incinerates it via its "self cleaning oven" regen mode and you are correct that it senses the need to clean via the pressure differential across the DPF. NOx is a totally different issue and the DEF works with the SCR (selective catalytic reduction) to convert harmful NOx to nitrogen and water. Of course both are necessary to meet current emissions standards.
The plus of the DEF/SCR system is the engine can be set up to produce more NOx than older systems meeting the previous standards and this can be used to achieve more power and efficiency. Too bad the EPA doesn't give you a choice of either controlling particulates or NOx because even though the NOx system is responsible for the current CELs in some of the 2018 production it doesn't hurt mileage or create plugged filter from idling issues like the DPF system.
Is the service info saying what the def/fuel ratio should be for the L5P?
( IIRC, the public docd from 2011 time frame said 1.25% or 1.5% of fuel )
Picked my rig up on Wednesday. Dealer said they've had to reprogram about 20% of the trucks from the factory due to excessive DEF usage.
The person you were talking to is full of of crap.
Programming won't be different on 20% of them.....
(if there was a programming change, then it would be vehicles before a certain build date (or serial number) not a random 20%)
Reactions: wq93
Not saying I believed it. Just relaying what was said.
I'm more prone to believe that they have to make adjustments on some. I doubt it's 20% as well. They'd have a bulliten out if it was that high.
1 - 20 of 56 Posts
