1 - 18 of 18 Posts
2016 Chevy LML 2500 4x4 bone stock CCLB summit white, air ride on board air, b&w gneck hitch
I think I figured out y my truck has a vibration when I'm turned full left but dunno how it got this way or how to fix it. Any input is really appreciated. Here is a pic of the front right side. The left side looks good. Another dumb question. What is it that my tire is rubbing on?
Wheel Auto part Automotive wheel system Rust Tire
Ok. But y does the passenger side rub and my driver side don't? What could cause it and how should I go about fixing it?
Anybody have any ideas?
I'm not sure why one side rubs and one doesn't. Mine rubs on both sides a good bit. The fix would be to run a different wheel or a narrower tire setup.
O ok thanks for the input. That bugs me tho that one side rubs and the other side don't
Lol. Yea. What's weird is I used to have the nitto trail grapplers on here before the mickeys. Same exact size and no rub
Guess nobody knows how to fix this problem?
I've always heard that one tire actually leans out more when you turn than the other on GM vehicles so that's why it only rubs on one side! As far as how to fix it, some wheels with more backspacing or more of a negative offset would fix your problem. Then your gonna rub elsewhere but it'll stop it from rubbing on the swaybar :)
Ok thank u greydmax. Lets me feel better bout my tire rubbin
I wonder if your sway bar isn't perfectly centered either. It could be sitting in the bushings slightly more to one side than the other.
How do I go bout fixing that.
Good question. You could try hitting it with a hammer but honestly I don't really know.
I'd have to look at mine when I get home to have any idea
Discussion Starter · #16 ·
K thanks
Well I checked mine and I can't see a way to adjust it. Only other thing I can think of is have the alignment checked. There might be something off there.
Discussion Starter · #18 ·
Ok thanks again
1 - 18 of 18 Posts
