2G1FP22G022105949
02 camaro ss thank you so much in advance!
Here is your vehicle build.
Vehicle: CAMARO
Year: 2002
RPO
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
UZ7 SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER 8 SPKR SYS(UZ7)
U1S PLAYER MULTIPLE COMPACT DISC MULTIPLE CD PLYR(U1S)
U73 ANTENNA,FIXED FIXED ANT(U73)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V12 COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WU8 SALES PACKAGE CAMARO SS APPEARANCE AND PERFORMANCE CAMARO SS APPEARANCE & PERFORMANCE PKG(WU8)
Y2Y SALES PACKAGE - CAMARO SS DUAL LABEL
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
1SD PACKAGE-OPTION 04 (1SD)
1SZ PACKAGE OPTION- (1SZ)
11Q MOLDING COLOR,PEWTER (11Q)
11U EXTERIOR COLOR,PEWTER MET (11U)
EXTERIOR COLOR,PRIMARY (11U)
19I INTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
INTERIOR TRIM,EBONY (19I)
192 TRIM COMBINATION,BLACK LEATHER (192)
6BS SPRING COMPTR SELECT FRT LH SUSP(6BS)
7BS SPRING COMPTR SELECT FRT RH SUSP(7BS)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
CAE HANDLING CHARGE - GM ST THERESE TO SLP LASALLE QUEBEC FOR UPFITTER CONVERSION (VTIMS)
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IP2 TRIM,INTERIOR DESIGN (IP2)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K43 GENERATOR 102 AMP 102 AMP(K43)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NW9 TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
N73 WHEEL,CUSTOM SPORT PAINTED AL WHL(N73)
PBT TEMPORARY HOOD FOR UPFITTER DELIVERY
QFK TIRE ALL P275/40ZR17 93W BW R/PE ST TL HW4 TIRE(QFK)
SLM SALES PROCESSING - STOCK ORDERS
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
TS9 LAMP STOP, HIGH LEVEL, DELETE TS9)
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
CC
thank you sir!!!!
