I have a 2003 I picked up with a busted cluster and was wondering if I could get a VIN check. Really wondering if the injectors have been done.
1GCHK24193E301935
Thanks
Brent
Yep!!!
Vehicle Information
VIN: 1GCHK24193E301935 Model: CK25903-2003 SILVERADO 2500HD 4WD REG CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 09/25/2003 110 MI 09/25/2008 100,110 MI
Special Coverage-07187 09/25/2003 110 MI 09/25/2010 80,110 MI
Bumper to Bumper Limited Warranty 09/25/2003 110 MI 09/25/2006 36,110 MI
Special Coverage 04039 09/25/2003 110 MI 09/25/2010 200,110 MI
Diesel Engine Ltd Wty with Deductible 09/25/2003 110 MI 09/25/2008 100,110 MI
Corrosion Limited Warranty 09/25/2003 110 MI 09/25/2009 100,110 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
01/29/2009 510759 ZREG----Regular Vehicle Transaction T5603 - 04039 - Replace all 8 Fuel Injectors 86,767 MI
11/02/2005 108434 ZREG----Regular Vehicle Transaction B1791 - Rear Window Washer Nozzle Replacement 29,577 MI
11/02/2005 108434 ZREG----Regular Vehicle Transaction B5800 - Endgate Handle Replacement 29,577 MI
09/01/2005 104887 ZREG----Regular Vehicle Transaction F1003 - Rear Propeller Shaft Rear Universal Joint Replacement 26,560 MI
09/01/2005 104887 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 26,560 MI
09/01/2005 104887 ZFAT----Field Action Recall V1380 - 05546 - Replace Fuel Filter 26,560 MI
04/04/2003 A01935 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Information
Vehicle Build
Model: CK25903-2003 SILVERADO 2500HD 4WD REG CAB Order Number: GCJP44
Gross Vehicle Weight: 4,177 Build Date: 04/04/2003
Build Plant: E
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
11U - LT PEWTER METALLIC 1SB - LS DECOR INCLUDES: * AIR COND, DUAL ZONE MANUAL * DUAL PWR HEATED OSRV MIRRORS * REAR WINDOW DEFOGGER * AM/FM STEREO W/CD PLAYER * CHROME STYLED STEEL WHEELS * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * BODY SIDE MOLDINGS * ISRV MIRROR W/COMPASS & TEMP * LEATHER WRAPPED STEERING WHL UNIT PRODUCED WITHOUT: * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM
1SZ - PREFERRED EQUIPMENT SAVINGS 69D - DARK CHARCOAL - CUSTOM CLOTH
69I - DK PEWTER INTERIOR TRIM 6GL - FRONT SPRING
7GL - FRONT SPRING A31 - POWER WINDOWS
AE7 - 40/20/40 SPLIT BENCH RECLINING FRONT SEAT AU0 - KEYLESS REMOTE DOOR LOCK
AU3 - POWER DOOR LOCK SYSTEM B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B71 - WHEEL OPENING FLARES
B85 - BLACK BODY SIDE MOLDINGS C49 - ELECTRIC REAR WINDOW DEFOGGER
C6W - GVW RATING - 9,200 LBS CJ3 - AIR COND., DUAL ZONE MANUAL
DF5 - ISRV MIRROR W/COMPASS & TEMP DK7 - INTERIOR CUSTOM ROOF CONSOLE
DPF - OSRV RETRACTABLE CAMPER STYLE POWER MIRRORS W/TURN SIGNAL AND HEAT E63 - FLEETSIDE BODY
FE9 - FEDERAL/NY/VT EMISSIONS FT2 - ARM TORS BAR SPRING ADJ
FT3 - ARM TORS BAR SPRING ADJ G80 - LOCKING DIFFERENTIAL-REAR AXLE
GMC - ASSEMBLY PLANT-PONTIAC EAST GT4 - REAR AXLE - 3.73 RATIO
HVY - IDEN 2 INCH BODY RAISE,HD MODEL JH6 - 4 WHEEL POWER DISC BRAKES, HD
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER K68 - 105 AMP DELCOTRON GENERATOR
KC4 - ENGINE OIL COOLING SYSTEM KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC LB7 - DURAMAX DIESEL 6600 V8 ENGINE
M74 - ALLISON 5 SPD AUTOMATIC TRANS NF2 - FEDERAL EMISSION SYSTEM
NP1 - ELECTRONIC SHIFT TRANSFER CASE NP5 - LEATHER WRAPPED STEERING WHEEL
NZZ - OFF ROAD - SKID PLATES PDD - COLOR-KEYED CARPET
PY0 - POLISHED ALUMINUM WHEELS QIW - LT245/75R16/E OOR BW TIRES
R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS TQ3 - BATTERY 770 CCA (DUAL)
TR3 - CHROME GRILLE UB1 - AM/FM STEREO W/CD & CASSETTE
UQ3 - ENHANCED AUDIO SPEAKERS UY2 - CAMPER/5TH WHEEL TRAILER WIRING PROVISIONS
V10 - COLD-CLIMATE PACKAGE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VB3 - CHROME REAR STEP BUMPER VG3 - FRONT DELUXE CHROMED BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION XGK - LT245/75R16/E OOR BW TIRES-FRNT
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
YE9 - SILVERADO YGK - LT245/75R16/E OOR BW TIRES-REAR
Z82 - HEAVY DUTY TRAILERING EQUIPMENT Z85 - HEAVY DUTY SUSPENSION
ZGK - LT245/75R16/E OOR BW SPARE TIRE ZY1 - SOLID PAINT
Thanks that really helps. Have a great weekend.
Brent
