I was involved in an accident and the truck was totaled. Im arguing with the insurance company over options on the truck. Can I get a build sheet for my truck please?
VIN # 1GCHK23618F152564
Vehicle Information
VIN: 1GCHK23618F152564 Model: CK20743-2008 SILVERADO 2500 4WD CREW CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type
Number
Original Nbr
Description
Release Date
Status
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Customer Satisfaction Program N080142 08142 ECM EEPROM - REPROGRAM ECM 05/12/2008 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: Z1CRW080 XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid
Description
Start Date
Effective Odometer
End Date
End Odometer
Diesel Engine Limited Warranty 02/15/2008 26 MI 02/15/2013 100,026 MI
Bumper to Bumper Limited Warranty 02/15/2008 26 MI 02/15/2011 36,026 MI
Powertrain Limited Warranty 02/15/2008 26 MI 02/15/2013 100,026 MI
Emission Limited Warranty 02/15/2008 26 MI 02/15/2013 50,026 MI
Corrosion Limited Warranty 02/15/2008 26 MI 02/15/2014 100,026 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date
Job Card Number
Transaction Type
Transaction Adjustment
Labour Operation
Odometer Reading
04/18/2012 331902 ZREG----Regular Vehicle Transaction L1197 - Fuel Level Sensor Replacement 71,076 MI
10/24/2011 73714 ZREG----Regular Vehicle Transaction J4761 - Plugs, Glow (Diesel) - Left - Replace 64,215 MI
01/03/2011 302921 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 51,303 MI
01/03/2011 302921 ZREG----Regular Vehicle Transaction L1200 - Fuel Tank Fuel Pump Module Replacement 51,303 MI
10/14/2008 256327 ZREG----Regular Vehicle Transaction C2865 - Bezel, Roof Console - Replace 10,598 MI
10/14/2008 256327 ZREG----Regular Vehicle Transaction T5716 - 08048 - Remove Heated Windshield Washer 60 Amp Fuse 10,598 MI
10/14/2008 256327 ZFAT----Field Action Recall V1819 - 08142 ECM EEPROM - Reprogram ECM 10,598 MI
10/14/2008 256327 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 10,598 MI
03/10/2008 W90399 ZREG----Regular Vehicle Transaction B7010 - Emblem/Nameplate Replacement 1,124 MI
10/30/2007 A52564 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Vehicle Information
Vehicle Build
Model: CK20743-2008 SILVERADO 2500 4WD CREW CAB Order Number: MJDX7N
Gross Vehicle Weight: 4,177 Build Date: 10/30/2007
Build Plant: F
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
193 - EBONY 19I - EBONY
1LZ - SILVERADO LTZ EQUIPMENT GROUP: * 10 WAY POWER HEATED BUCKET SEATS W/DRIVER MEMORY * LEATHER APPOINTED SEATING SURFACES * OSRV MIRRORS W/POWER FOLD & ADJ, HEAT, TILT, TURN SIGNAL AND DRIVER SIDE AUTO DIMMING * BOSE PREMIUM SPEAKER SYSTEM * HEATED WASHER FLUID SYSTEM * REMOTE VEHICLE START * HD TRAILERING EQUIPMENT * LOCKING REAR DIFFERENTIAL * STEERING WHEEL RADIO CONTROLS * POWER LOCKS AND WINDOWS * ISRV MIRROR W/AUTO DIMMING, COMPASS & TEMPERATURE * REAR AUDIO CONTROLS * BODYSIDE MOLDINGS * LEATHER WRAP STEERING WHEEL * REMOTE KEYLESS ENTRY * ILLUMINATED VANITY MIRRORS * ELECTRONIC SHIFT TRANSFER CASE 1SZ - OPTION PKG DISCOUNT
50U - SUMMIT WHITE 6GL - FRONT SPRING
7GL - FRONT SPRING A31 - POWER WINDOWS
A60 - TAILGATE LOCK A68 - SEAT, 60/40 REAR FOLDING BENCH
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 10-WAY POWER PASSENGER SEAT
AJ1 - DEEP TINTED GLASS AN3 - FULL FEATURE BUCKET SEATS
AP3 - REMOTE VEHICLE START AT8 - RESTRAINT CHILD PROVISIONS
AU3 - POWER DOOR LOCKS WITH REMOTE KEYLESS ENTRY B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B85 - BODY SIDE MOLDING C49 - ELECTRIC REAR WINDOW DEFOGGER
C6W - GVW RATING - 9,200 LBS CJ2 - DUAL-ZONE AUTO AIR CONDITIONING
CMD - ASSEMBLY PLANT - FLINT, MI D07 - CUSTOM FRONT FLOOR CONSOLE
DF5 - ISRV MIRROR W/COMPASS & TEMP DH6 - LIGHTED VISOR/VANITY MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL (REPLACES STD/PKG MIRROR)
E63 - FLEETSIDE BODY FE9 - 50-STATE EMISSIONS
FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ
G80 - LOCKING REAR DIFFERENTIAL GT4 - REAR AXLE - 3.73 RATIO
JF4 - POWER ADJUSTABLE PEDALS JH6 - 4 WHEEL POWER DISC BRAKES, HD
JL1 - BRAKE CONTROLLER K05 - ENGINE BLOCK HEATER
K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
KC4 - ENGINE OIL COOLING SYSTEM KG7 - 125 AMP GENERATOR
KNP - HD AUX TRANS. COOLING SYSTEM LMM - ENGINE, 6.6L DURAMAX DIESEL
MW7 - ALLISON 6 SPEED AUTO TRANS N79 - SPARE WHEEL, STEEL
NP5 - LEATHER WRAPPED STEERING WHEEL NQF - TRANSFER CASE, ELECTRONIC
NT8 - EMISSION SYSTEM FEDERAL, TIER NZZ - OFF ROAD - SKID PLATES
P25 - 17" ALUMINUM WHEELS PCW - SAFETY PACKAGE: * ADJUSTABLE PEDALS * REAR PARKING ASSIST
PDF - EZ LIFT TAILGATE PACKAGE: * LOCKING TAILGATE * EZ LIFT TAILGATE PPA - TAILGATE ASSIST
QXT - LT265/75R17 AT TIRES R6K - PROCESSING CODE
R9N - PROCESSING CODE R9U - GM ACCESS - AUTOBOOK IDENTIFIER
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS SLT - EQUIP CHEV 'LT' SALES PKG
T74 - HEADLAMPS T96 - FOG LAMPS
TUV - BATTERY, DUAL U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
UD7 - ULTRASONIC REAR PARKING ASSIST UE1 - 1YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UG1 - UNIVERSAL HOME REMOTE UJ6 - TIRE PRESSURE MONITOR
UK3 - STEERING WHEEL RADIO CONTROLS UK6 - REAR SEAT AUDIO CONTROLS
UQA - BOSE PREMIUM SPEAKER SYSTEM US9 - AM/FM STEREO W/MP3 FORMAT COMPATIBLE 6-DISC CD CHANGER (REPLACES STD/OPT RADIO)
V22 - CHROME GRILLE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS VB3 - CHROME REAR BUMPER
VG3 - FRONT BUMPER VH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VT7 - OWNERS MANUAL ENGLISH VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION XA7 - HEATED WASHER FLUID SYSTEM
YD3 - BASE AXLE YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING YE9 - SILVERADO
Z71 - OFF ROAD SUSPENSION PACKAGE: * SKID PLATES Z82 - HD TRAILERING EQUIPMENT
ZER - SPARE TIRE, LT265/75R16 BW OOR ZY1 - SOLID PAINT
