1 - 2 of 2 Posts
Vehicle Information
VIN: 1GC4K0C80BF107224 Model: CK30943-2011 SILVERADO 3500 4WD CREW CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N110035 11035 NOISE LABEL MISSING - INSTALL LABEL 05/02/2011 Closed
Product Emission Recall N110001 11001 DIESEL EXHAUST FLUID CAL TO PREVENT COLD WEATHER (FREEZE) CONCERNS/FLUID LEVEL 07/18/2011 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: 27816280 XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 05/02/2011 599 MI 05/02/2016 50,599 MI
Emission Select State Component Ltd Wty 05/02/2011 599 MI 05/02/2018 70,599 MI
Corrosion Limited Warranty 05/02/2011 599 MI 05/02/2017 100,599 MI
Diesel Engine Limited Warranty 05/02/2011 599 MI 05/02/2016 100,599 MI
Special Coverage 14353 05/02/2011 599 MI 05/02/2021 120,599 MI
Special Coverage 13386 05/02/2011 599 MI 05/02/2021 120,599 MI
Bumper to Bumper Limited Warranty 05/02/2011 599 MI 05/02/2014 36,599 MI
Powertrain Limited Warranty 05/02/2011 599 MI 05/02/2016 100,599 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
02/19/2015 6083439 ZREG----Regular Vehicle Transaction 4026050 - Nitrogen Oxides Sensor Replacement - Position 1 82,749 MI
06/02/2014 562903 ZREG----Regular Vehicle Transaction 4025860 - Exhaust Temperature Sensor Replacement - Position 2 76,801 MI
06/02/2014 562903 ZREG----Regular Vehicle Transaction 4025840 - Exhaust Temperature Sensor Replacement - Position 1 76,801 MI
02/21/2014 6073584 ZREG----Regular Vehicle Transaction 4025130 - Emission Reduction Fluid Tank Replacement 68,704 MI
02/21/2014 6073584 ZREG----Regular Vehicle Transaction 4026070 - Nitrogen Oxides Sensor Replacement - Position 2 68,704 MI
12/19/2013 6548884 ZREG----Regular Vehicle Transaction 2810075 - Engine Control Module Reprogramming with SPS 62,935 MI
12/19/2013 6548884 ZREG----Regular Vehicle Transaction 4026070 - Nitrogen Oxides Sensor Replacement - Position 2 62,935 MI
05/29/2012 6528064 ZREG----Regular Vehicle Transaction R5538 - USB Receptacle Replacement 25,220 MI
05/29/2012 6528064 ZFAT----Field Action Recall V2193 - 11035 - Install Noise Label 25,220 MI
05/29/2012 6528064 ZREG----Regular Vehicle Transaction C6588 - Driver or Passenger Seat Inner Adjuster Finish Cover Replacement 25,220 MI
08/09/2011 6028092 ZFAT----Field Action Recall V2399 - 11001 - Reprogram ECM 6,017 MI
05/18/2011 6024065 ZREG----Regular Vehicle Transaction B7010 - Emblem And/Or Nameplate - One - Replace 2,517 MI
07/27/2010 6505070 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 3 MI
07/18/2010 A07224 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
BUILD
Vehicle Information
Vehicle Build
Model: CK30943-2011 SILVERADO 3500 4WD CREW CAB Order Number: NWQF72
Gross Vehicle Weight: 5,266 Build Date: 06/22/2010
Build Plant: F
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
19C - EBONY 19I - EBONY
1LT - SILVERADO LT1 EQUIPMENT GROUP 1SZ - MARKET PACKAGE IDENTIFIER SAVINGS
A31 - POWER WINDOWS A48 - POWER SLIDING REAR WINDOW (DELETES REAR WINDOW DEFOGGER)
A60 - LOCKING TAILGATE WITH EZ LIFT A68 - SEAT, 60/40 REAR FOLDING BENCH
AG1 - SEAT ADJUSTER-DRIVER SIDE 6-WAY AJ1 - DEEP TINTED GLASS
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG AM1 - MANUAL LUMBAR, DRIVER
AP3 - REMOTE VEHICLE START AT8 - RESTRAINT CHILD PROVISIONS
AU3 - POWER DOOR LOCKS AXK - VEHICLE TYPE TRUCK
AZ3 - SEATS, FRONT 40/20/40 BENCH, CLOTH B30 - CARPETING, COLOR-KEYED
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B85 - BODY SIDE MOLDING C7V - GVW RATING - 11,600 LBS
CJ2 - DUAL-ZONE AUTO AIR CONDITIONING CMD - ASSEMBLY PLANT - FLINT, MI
DD8 - INSIDE REARVIEW MIRROR, AUTO- DIMMING DH6 - LIGHTED VISOR/VANITY MIRRORS
DK8 - DELUXE OVERHEAD CONSOLE DPN - MIRRORS, CAMPER STYLE, HEATED, POWER ADJUSTABLE
E63 - FLEETSIDE BODY EF7 - U.S. COUNTRY CODE
G80 - LOCKING REAR DIFFERENTIAL GGZ - SHEER SILVER METALLIC
GT4 - REAR AXLE - 3.73 RATIO J95 - BRAKE HYD POWER, SRW, 4WHL DISC
JL1 - TRAILER BRAKE CONTROLLER JL4 - STABILITRAK-STABILITY CONTROL W/ TRACTION CONTROL SYSTEM
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K40 - ENGINE EXHAUST BRAKE K47 - HIGH CAPACITY AIR CLEANER
K76 - DUAL 125 AMP ALTERNATOR KC4 - ENGINE OIL COOLING SYSTEM
KNP - HD AUX TRANS. COOLING SYSTEM LML - DURAMAX 6.6L V8 TURBO DIESEL
MW7 - ALLISON 6-SPEED AUTOMATIC TRANS N79 - SPARE WHEEL, STEEL
NC7 - FEDERAL OVERRIDE NE1 - 50-STATE EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHEEL NQF - TRANSFER CASE, ELECTRONIC
NU2 - EMISSION SYSTEM CALIFORNIA LEV2 NZZ - OFF ROAD SKID PLATE PACKAGE
PCM - INTERIOR PLUS PACKAGE: * PWR SEAT ADJUST, DRIVER 6-WAY * AUTO DUAL ZONE A/C * STEERING WHEEL RADIO CONTROLS * CD PLAYER W/ USB PORT * BLUETOOTH FOR PHONE PDD - EXTERIOR PLUS PACKAGE: * REMOTE VEHICLE STARTER SYSTEM * LOCKING TAILGATE * EZ LIFT TAILGATE * FOG LAMPS
PPA - EZ LIFT TAILGATE PYV - 18" FORGED POLISHED ALUM WHEELS
QGM - 18" ALL-TERRAIN BLACKWALL TIRES R8A - LAM INVOICE EXEMPTIONS
R9N - PROCESSING CODE R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
SRW - SINGLE REAR WHEEL T74 - HEADLAMPS
T96 - FOG LAMPS TRW - PROVISIONS-ROOF MOUNTED LAMP
TUV - BATTERY, DUAL U01 - ROOF MARKER LAMPS
U2K - XM RADIO - SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS/XM AFTER 3 MONTHS UE1 - 6 MTHS ONSTAR DIRECTIONS & CONNECTIONS WITH AUTOMATIC CRASH RESPONSE AND TURN-BY- TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
UK3 - STEERING WHEEL RADIO CONTROLS UPF - BLUETOOTH FOR PHONE
UQ3 - ENHANCED AUDIO SPEAKERS USR - USB PORT
UUI - AM/FM STEREO, CD PLAYER WITH USB PORT V22 - CHROME GRILLE
V76 - FRONT RECOVERY HOOKS V8D - VEHICLE STATEMENT
VB3 - CHROME REAR BUMPER VG3 - FRONT BUMPER
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VT7 - OWNERS MANUAL ENGLISH VYU - SNOW PLOW PREP PACKAGE: * ROOF LAMP PROVISION * DUAL 125 AMP ALTERNATORS ******************************* * WITHOUT SKID PLATES * *******************************
X88 - CHEVROLET CONVERSION XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE
YD3 - BASE AXLE YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING YE9 - SILVERADO
Z71 - OFF ROAD SUSPENSION HIGH CAPACITY AIR CLEANER Z82 - HD TRAILERING EQUIPMENT PKG: * INTEGRATED TRAILER BRAKE CONTROLLER
ZWF - 18" ALL-SEASON BW SPARE TIRE ZY1 - SOLID PAINT
1 - 2 of 2 Posts
