Vehicle Information
VIN: 1GCHK29648E185698 Model: CK20753-2008 SILVERADO 2500 4WD EXT CAB
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N080142 08142 ECM EEPROM - REPROGRAM ECM 05/12/2008 Closed
Customer Satisfaction Program N090184 09184 MATERIAL OVER SENSING & DIAGNOSTIC MODULE RETAINING MOISTURE 10/19/2009 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: CXLDY04U XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Powertrain Limited Warranty 09/10/2008 186 MI 09/10/2013 100,186 MI
CBG Certified Pre-Owned Limited Warranty 04/17/2012 34,096 MI 04/17/2013 46,096 MI
Special Coverage 14308 09/10/2008 186 MI 09/10/2018 150,186 MI
Standard CBG CPO Maintenance Plan 04/17/2012 34,096 MI 04/17/2014 64,096 MI
Bumper to Bumper Limited Warranty 09/10/2008 186 MI 09/10/2011 36,186 MI
Corrosion Limited Warranty 09/10/2008 186 MI 09/10/2014 100,186 MI
Emission Limited Warranty 09/10/2008 186 MI 09/10/2013 50,186 MI
Diesel Engine Limited Warranty 09/10/2008 186 MI 09/10/2013 100,186 MI
Service Contract
Policy Number: 900445731 Owner: HESLOP
Description: GMPP Major Guard Used Deductible Amount: 100.00
Effective Date: 04/17/2012 Expiration Date: 04/17/2016
Effective Odometer: 34096 MI Expiration Odometer: 74096 MI
Daily Rental Limit: 35.00
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
02/26/2013 553104 ZREG----Regular Vehicle Transaction F2122 - Carrier Assembly - Front Differential - R&R 46,638 MI
02/26/2013 553104 ZREG----Regular Vehicle Transaction J4640 - Starter Replacement 46,638 MI
11/07/2012 546747 ZREG----Regular Vehicle Transaction J5750 - Elbow And/Or Hose, Turbocharger Air Intake - Replace 44,780 MI
11/07/2012 546747 ZREG----Regular Vehicle Transaction B4260 - Front Side Door Lock Replacement 44,780 MI
11/07/2012 546747 ZREG----Regular Vehicle Transaction N2131 - Door Lock and Side Window Switch Replacement - Driver Side 44,780 MI
08/07/2012 6014273 ZREG----Regular Vehicle Transaction J0990 - Oil Pan Drain Plug Replacement 40,956 MI
07/20/2012 6013789 ZREG----Regular Vehicle Transaction B5800 - Endgate Handle Replacement 40,633 MI
03/29/2012 421211 ZREG----Regular Vehicle Transaction B7010 - Emblem And/Or Nameplate - One - Replace 34,042 MI
07/25/2011 402182 ZREG----Regular Vehicle Transaction B4261 - Front Side Door Lock Replacement - Left Side 28,647 MI
12/06/2010 384781 ZREG----Regular Vehicle Transaction B9886 - R&R Left and Right Front Door Regulators - Apply Lubrication to Regulator Rails 24,235 MI
12/06/2010 384781 ZREG----Regular Vehicle Transaction K9529 - Transmission Fluid Cooler Upper Pipe Assembly Replace 24,235 MI
08/11/2010 375831 ZFAT----Field Action Recall V2133 - 09184 - SDM Corrosion - Remove acoustical pad from the SDM area 19,658 MI
08/11/2010 375831 ZREG----Regular Vehicle Transaction Add Credit B4010 - Front Side Door Upper Hinge and Lower Hinge Replacement 19,658 MI
08/11/2010 375831 ZREG----Regular Vehicle Transaction Full Debit - Reversal B4010 - Front Side Door Upper Hinge and Lower Hinge Replacement 19,658 MI
08/11/2010 375831 ZREG----Regular Vehicle Transaction B4010 - Front Side Door Upper Hinge and Lower Hinge Replacement 19,658 MI
09/28/2009 353040 ZREG----Regular Vehicle Transaction B7876 - Molding, Front Door - Left - Side - R&R Or Replace 10,251 MI
07/30/2009 348786 ZREG----Regular Vehicle Transaction B7876 - Molding, Front Door - Left - Side - R&R Or Replace 9,613 MI
09/23/2008 542361 ZREG----Regular Vehicle Transaction B0761 - Engine Splash Shield Replacement - Left Side 604 MI
09/23/2008 542361 ZFAT----Field Action Recall V1819 - 08142 ECM EEPROM - Reprogram ECM 604 MI
02/06/2008 A85698 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
BUILD
Vehicle Information
Vehicle Build
Model: CK20753-2008 SILVERADO 2500 4WD EXT CAB Order Number: MPJDXH
Gross Vehicle Weight: 4,177 Build Date: 02/06/2008
Build Plant: E
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
16U - GRAYSTONE METALLIC 19C - EBONY
19I - EBONY 1SZ - OPTION PKG DISCOUNT
2LT - SILVERADO LT2 EQUIPMENT GROUP: * FRONT BUCKET SEATS W/POWER DRIVER/PASS SEAT ADJUSTERS * STEERING WHEEL RADIO CONTROLS * POWER LOCKS AND WINDOWS * ISRV MIRROR W/AUTO DIMMING, COMPASS & TEMPERATURE * DUAL PWR HEATED OSRV MIRRORS * BODYSIDE MOLDING * LEATHER WRAP STEERING WHEEL * REMOTE KEYLESS ENTRY * ILLUMINATED VANITY MIRRORS * REAR ACCESS DOOR PWR WINDOWS * ELECTRONIC SHIFT TRANSFER CASE 6GL - FRONT SPRING
7GL - FRONT SPRING A31 - POWER WINDOWS
A60 - TAILGATE LOCK A68 - SEAT, 60/40 REAR FOLDING BENCH
A95 - SEATS, FRONT BUCKET ABV - POWER REAR SIDE WINDOW
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 10-WAY POWER PASSENGER SEAT
AJ1 - DEEP TINTED GLASS AM1 - MANUAL LUMBAR, DRIVER
AP8 - REMOTE VEHICLE STARTER PREP PKG AU3 - POWER DOOR LOCKS WITH REMOTE KEYLESS ENTRY
B30 - CARPETING, COLOR-KEYED B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B85 - BODY SIDE MOLDING
C49 - ELECTRIC REAR WINDOW DEFOGGER C6W - GVW RATING - 9,200 LBS
C99 - IP SWITCH CJ2 - DUAL-ZONE AUTO AIR CONDITIONING
D07 - CUSTOM FRONT FLOOR CONSOLE DF5 - ISRV MIRROR W/COMPASS & TEMP
DH6 - LIGHTED VISOR/VANITY MIRRORS DK8 - DELUXE OVERHEAD CONSOLE
DL8 - DUAL PWR HEATED OSRV MIRRORS E63 - FLEETSIDE BODY
FE9 - 50-STATE EMISSIONS FT2 - ARM TORS BAR SPRING ADJ
FT3 - ARM TORS BAR SPRING ADJ G80 - LOCKING REAR DIFFERENTIAL
GMC - ASSEMBLY PLANT-PONTIAC EAST GT4 - REAR AXLE - 3.73 RATIO
JH6 - 4 WHEEL POWER DISC BRAKES, HD JL1 - BRAKE CONTROLLER
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER KC4 - ENGINE OIL COOLING SYSTEM
KG7 - 125 AMP GENERATOR KNP - HD AUX TRANS. COOLING SYSTEM
LMM - ENGINE, 6.6L DURAMAX DIESEL MW7 - ALLISON 6 SPEED AUTO TRANS
NP5 - LEATHER WRAPPED STEERING WHEEL NQF - TRANSFER CASE, ELECTRONIC
NT8 - EMISSION SYSTEM FEDERAL, TIER NZ3 - FULL SIZE SPARE WHEEL
PDF - EZ LIFT TAILGATE PACKAGE: * LOCKING TAILGATE * EZ LIFT TAILGATE PPA - TAILGATE ASSIST
PY0 - POLISHED ALUMINUM WHEELS QIZ - LT245/75R16/E ALS BW TIRES
R9N - PROCESSING CODE R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
T74 - HEADLAMPS T96 - FOG LAMPS
TUV - BATTERY, DUAL U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
UE1 - 1YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE) UJ6 - TIRE PRESSURE MONITOR
UK3 - STEERING WHEEL RADIO CONTROLS UQ3 - ENHANCED AUDIO SPEAKERS
US8 - AM/FM STEREO WITH CD/MP3 UY2 - CAMPER/5TH WHEEL TRAILER WIRING PROVISIONS
V22 - CHROME GRILLE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS VB3 - CHROME REAR BUMPER
VG3 - FRONT BUMPER VH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VT7 - OWNERS MANUAL ENGLISH VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET CONVERSION YD3 - BASE AXLE
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YE9 - SILVERADO Z82 - HD TRAILERING EQUIPMENT
Z85 - HEAVY DUTY SUSPENSION ZIZ - SPARE TIRE, LT245/75R16 ALS BW
ZY1 - SOLID PAINT
