I saw a price of $650. That's a lot for 2 filters, in my opinion. Granted, there are some electronics to detect water in the filter but still seems like a lot of $$ to me. Very nice unit though.
If the fuel is gelled the oem filter is going to fail I would imagine. The filter and filter head were intended to be used and designed for a 1.8l diesel. The l5p is probably stressing that setup pretty hard under good conditions so as soon as something goes a bit funky fuel wise it explodes. Which would account for the folks running the oem filters and nuking the engines when dirty fuel is encountered.Albeit they are larger separate dirt/water filters if you have a Gell event or think you've had a dirty fuel event change you filter asap. It's been discussed on here that that fuel pressure is normally around 60psi, but those that monitor that pressure have said to have seen 90+. The Donaldson filters have a Burst pressure of 90 psi just like the factory filter. Prolly never see enough dirt to cause an issue that extreme but a gelled event with attempted starts definitely could. Just a thought.
I'm going to setup data logging on the idash for the lift pump and see how it performs during next regen and try and watch it over the next few weeks.$650 seems pretty cheap to me, if you know what I mean. Yeah I'm sure at that price they're making plenty of profit for a dual filter head setup but it could be invaluable for your truck. It'll be a high priced option until some real competition shows up.
Good write-up on the install. Looks like a nice setup.
Maybe I missed it but how do we know this filter was actually designed for the Cruze diesels? For a car that can get 50 mpg, the filter seems huge for something that would use a couple gallons per hour. The Cruze diesel always seemed like an afterthought to me (had a 2014 gas Cruze) and maybe the engineers just used a truck filter on it instead of designing something smaller.The filter and filter head were intended to be used and designed for a 1.8l diesel.
The cruz ended production about 2 years after l5p started. What better way to save cost by counting beans and reuse a filter they already had. It's highly unlikely gm was planning out the l5p in 2010 or so when the cruz was made by gm korea.Maybe I missed it but how do we know this filter was actually designed for the Cruze diesels? For a car that can get 50 mpg, the filter seems huge for something that would use a couple gallons per hour. The Cruze diesel always seemed like an afterthought to me (had a 2014 gas Cruze) and maybe the engineers just used a truck filter on it instead of designing something smaller.
Why? I have read about one collapse but no other problems. Seriously asking because I really do like the runvse setup but don't want to fight with the dealership while warranty is active.I just dont trust it.
Read this thread:Why? I have read about one collapse but no other problems. Seriously asking because I really do like the runvse setup but don't want to fight with the dealership while warranty is active.
I like the VSE filter and it almost certainly does a better job. Plus, it is a hell of a lot easier to change the filters since there is no plastic to strip or problems getting bad things in the cap. I agree there are probably more but how many Cat/Donaldson filter failures are there? : ) Not trying to turn this into an argument to not use the VSE or that the OEM filter is great. I was just wondering if there was some other reasons to not trust the OEM filter. If there were more reasons, I would consider switching a higher priority but I will probably wait for my warranty to run out.Seems like there must be a reason or the VSE filter solution and it's doubtful they funded the R&D over 3 filter failures. If there are 3 that we know of on this little forum, how many have there been in total?
The original filter for the Cruze was superseded by a new part number in 2017 for the L5P 6.6 diesels, the new part number was to be used in the 6.6 and smaller engines, Have found no info indicating that you can take an older pre 2017 cruze filter and use it in the newer truck and wouldn't suggest it. Not saying it wouldn't fit, you just wont find the old part number listed as a usable part number for the 6.6.Well for the Cruze and L5P, aren't they the same part number?
my reason is I spent almost 90k on this truck. I have zero monthly payment. the vse makes sense as donaldson makes some of the best filters. so a unit that will do the job and do it well with a filter setup that does not interfere with the computer system or require reprogramming I'm going to do itI like the VSE filter and it almost certainly does a better job. Plus, it is a hell of a lot easier to change the filters since there is no plastic to strip or problems getting bad things in the cap. I agree there are probably more but how many Cat/Donaldson filter failures are there? : ) Not trying to turn this into an argument to not use the VSE or that the OEM filter is great. I was just wondering if there was some other reasons to not trust the OEM filter. If there were more reasons, I would consider switching a higher priority but I will probably wait for my warranty to run out.
