Watched this VSE video on their filter solution. In his discussion, he shows fuel system parts downstream of the OEM filter showing rust and corrosion. He then talks about how their system functions “just like OEM”. Also talks about how the competition’s deeper single filter solutions hold “more water” below the sensor. I’m not sure I follow how their system is any better than OEM with respect to the water issue. It almost seemed like it was tacitly implied it was a better water solution. If you have water in contact with fuel, and their fuel/water separator doesn’t have a “magic bullet” better removal solution for water from the fuel you will still have some emulsified water traveling downstream creating the same corrosion issues.
While I see the great value of the two filter system separating the functions, the superior filter setup (flimsy cartridge that can tear, plastic housing subject to wrench failure vs metal screw-on) I’m skeptical that it helps with the corrosion they show on the “relatively new”, as he says, fuel system internals. They need to run a side-by-side test of two identical L5Ps (OEM fuel filter vs VSE) driving the same route, fueling at the same stations/fuel pumps for the total miles of the fuel system they they had in their video or further. Then do a fuel system tear down and check for corrosion. If their system showed no water based corrosion and the OEM did then VSE could say they have the TOTAL magic fuel filtration bullet. He drops the ball after discussing the water based corrosion issue. The deeper water depth, holding more water longer before setting a code is problematic. But, if you have water just below the sensor you still have a water/fuel interface.
What the fuel/water separator needs is a glass bowl of old - much more convenient to check - bleed when you see water. Much better than putting it off because you need something to catch bled fuel to periodically bleed it because you are “wondering” if there is water. With glass, you look, SEE NO water, go on your way, little to no inconvenience/time involved.
He has a bit of a discussion regarding their flow characteristics being better than OEM (5micron) even though they have a finer(3micron) filter media. They have increased the filter area which decreases the pressure it takes to push fuel through the filter. Even though their filter “holes” are smaller (3 vs 5 microns), they have increased the effective “open” area for the fuel to flow through by increasing the amount of area of filter material. They have increased the number of “holes” for the fuel to flow through even though they are smaller. They get an “A+” for that improvement.
