Anybody know how/where the washer fluid lines run?
Drivers squirts fine.
Passenger starts fine and peters out?
They run under the black plastic where wiper hinges are located from passenger to driver and then to the fender and then behind batterie. I have a similar issue but both of mine don't spray. I changed the pump and looked at the fuses I can't figure it out....
How the hell do you get the wipers off?
remove the nut under the black plastic cap on the pivot, they are on a taper and a little wiggling usually get them off.
Yeah I tried taking the nut off and pulling, didnt want to break anything until I knew they werent threaded somehow or somthing.
Knowing an LLY it was the first and only year they used locktite on the wiper arms....
Once you have the wiper nuts off, you have to push and pull on the wiper arm until it comes off. Sometimes takes a bit. The cowl has two end caps that clip in, pull those off, then there's a couple Torx head screws that have to come out, then the cowl can come off.
