1 - 8 of 8 Posts
How to reset the water in the fuel message?
Already drained the fuel filter housing and new filter
Diesel is clear but the message it's showing water in fuel
Do you have a scanner or cts2. That may be able to clear the code. If not the sensor is probably not working right. Did you actually have water in the fuel?
If no water was found in the fuel. Replace sensor.
Shouldn't have to reset it.
Are you sure there wasn't more water in tank that is now in new filter?
Diesel supplement has some troubleshooting info.
On the scanner, it is not showing any faults
Filter is clear off water
Message it's showing
The sensor is just a float on a stick,sensor is bad.
You can check it by taking sensor off running float up and down and checking water in fuel light, just make sure lift pump is disabled if you have one. Just closes or opens loop and sends signal to dash.
1 - 8 of 8 Posts
