My dad has a 2005 dmax with a lil over 300k on it. He was coming home last night and noticed a lil drop in the oil pressure so he got home checked the oil and its super milky. We changed the oil and filled up the coolant. as soon as i fired up the truck it sucks the coolant as fast as i can put it in. I shut the truck off and the oil is filled with coolant again. From what I have read on this site is that dmaxs will not put water into the oil from a head gasket. Is this true? If so what else could be the issue with coolant getting into the oil?? Thanks in advance..
· Premium Member
could be a bad water pump seal from what I was told by a diesel tech at the dealer. There is a seal on the pump that if it goes bad, it will mix the oil and coolant.
I am assuming you don't have any signs of a head gasket being bad correct? The upper radiator hose doesn't stay hard after a couple of hours does it?
There are no signs of it being the head gaskets. The upper hose stays pretty soft when running and about a min after I shut it off its really soft. Is there a way to check the water pump seal without teariing into it? Thanks for the help
· Premium Member
Not that I know. if the truck has 300k on it and never had that changed...that would be a good place to start.
