1 - 9 of 9 Posts
I have a water leak when it rains or I wash the truck that rubs down the drivers side pillar, on the fuse block then onto the Emergency brake pedal to the floor. Now my WiFi does not work properly and connect to the My GMC App on the touch screen even though it says it has full bars.
Discussion Starter · #2 ·
Sorry forgot to include truck
2019 GMC Sierra 3500hd Diesel SLT
If I remember correctly it’s the antenna seal on the roof leaking allowing water in.
Bring it to dealer. I had a water leak on my passenger side. Ended up being the windshield and a body seam on the roof. Good luck!
Sent from my SM-G930V using Tapatalk
I've got a 16 model and have had the same leak. My GPS doesn't work now either. I put a bead of silicone all around the antenna and the leak quit. (I don't have time to go to dealer right now)
Sent from my SM-G977U using Tapatalk
Mine was a seam that was not welded the hole way on the drivers side post.
I had that exact same thing on my 17 this summer. It was shark fin antenna and the seam gone. Took it to the dealer and they yanked it. Had enough moisture in there it started rusting the mount lag on the antenna but nothing on the truck. Got it replaced under warranty
If you have a sunroof check the drains. They could be plugged and leaking down or they could be a leaking drain. It’s a long shot but something to look at if you’ve got a sunroof
1 - 9 of 9 Posts
