1 - 16 of 16 Posts
I have an LB7 D with a bad water pump. I am located in Wisconsin. Has anyone had a repair garage replace the water pump for them. Could you give me the going cost to have the water pump replaced.
Got mine quoted today from the dealership. $300.00 for the Pump, and about $700-$800 for the labor... ... ... Looks like I will be changing a water pump this weekend.
Thats crazy. Its not a hard job
Yeah, all the repair books call for 9 hours of labor. Not sure what they're smoking, I did mine in two hours easy. Hardest part was getting the fan and harmonic balancer off.... I vote DIY, then buy yourself something nice for the truck with all the money you saved. Also, I only spent $150 for a new AC Delco pump and cover, gotta check google :thumbsup:
yea it's not to bad a job, buy the lisle tool for holding the engine and socket, sear on hear for a thread called something like do your water pump in an hour and fallow it. You can bang it out easy.
Pretty easy job there is some tricks you learn to speed it up after you do acouple I can do them in less than an hour now with new t stats.
I cannot justify that much money for a water pump so I am going to start the project today.
Best of luck to you. I found that I prefer to remove the entire fan clutch assy but that's up to you. 3 bolts and 2 nuts and its out. Helps if you have an adjustable angle ratchet too
Completed the project yesterday. DEFINITELY understand why the dealshirp was charging $1,000.00. Pain in the neck, but it is all done and I was able to treat rust while I had the truck tore apart.
Probably doing mine this weekend. Hopefully it won't be too bad. I've watched all the videos and I got all the tools I need for the job. Wish me luck.
Get a pump with a welded gear.
This. For a simple water pump replacement it is a real pita.
It's not too bad, i did mine in a little under 2 hours with burping the system. if you fallow the book instructions it will take you the 10 hours the dealer charges, but there is no need to remove the t-stat housing from the engine.
1 - 16 of 16 Posts
