I think my water pump is leaking but its not from the weep hole. It is leaking above the hole. There is a bolt boss for the water pump above the hole. The coolant is dripping from there or off there coming from above the boss. I cant see past there from underneath. Is there anything above that area it can leak from. It's a small leak. Started last week one day then stopped then showed up again.
Thanks. Mike
Thanks. Mike
