I guess if you could average 22.4166 mpg.They say it (36gal), but it doesn't happen.
It is driven by back pressure across the DPF. Drive cycle etc will determine how quickly this needs to be done.Just curious what starts the regen process ,mileage driven or hours engine is driven ,thanks
If you've put 11,000 miles on it, you're already doing everything that needs to be done.I am new to the Duramax diesel,i have a 2022 2500 hd crew. I have no clue what DPF or Regen means,or the soot stuff.Do i need to talk to a service rep to learn this stuff. I have 11k miles,95 percent expressway driving both empty and pulling 7500 lb travel trailer. i have used 12 gallons of DEF and have had 2 oil changes. MPG running empty at 70 i get 23.2, at 75 i get 21.7 at 80 i get 20.2, when pulling travel trailer 13.7 at 65,I use cruise for all expressway driving,and tow mode for pulling and still use my cruise,and keep tire pressure at 80lbs for my 18 inch tires,very happy with my truck and its performance.
No you don’t. There’s a reason GM doesn’t put any information on the dash for you because they plan for it to be transparent to the end user. Lots of us have something like an idash hooked up just to monitor this and other things. You’re using your truck as you should and everything is fine.I am new to the Duramax diesel,i have a 2022 2500 hd crew. I have no clue what DPF or Regen means,or the soot stuff.Do i need to talk to a service rep to learn this stuff. I have 11k miles,95 percent expressway driving both empty and pulling 7500 lb travel trailer. i have used 12 gallons of DEF and have had 2 oil changes. MPG running empty at 70 i get 23.2, at 75 i get 21.7 at 80 i get 20.2, when pulling travel trailer 13.7 at 65,I use cruise for all expressway driving,and tow mode for pulling and still use my cruise,and keep tire pressure at 80lbs for my 18 inch tires,very happy with my truck and its performance.
Thank you for all the details,Owning a diesel for the first time will be a learning trend.No you don’t. There’s a reason GM doesn’t put any information on the dash for you because they plan for it to be transparent to the end user. Lots of us have something like an idash hooked up just to monitor this and other things. You’re using your truck as you should and everything is fine.
Diesels produce soot, the DPF (diesel particulate filter) catches this spot before it exits your tail pipe. The filter eventually gets “full” of soot so your truck goes into a regeneration where it injects diesel fuel into your exhaust to raise your exhaust gas temperature (commonly referred to as EGT). It raises it to around 1100 iirc which essentially vaporizes the captured spot and turns it into ash thus “emptying” the filter.
Below is an article if you want to learn about the various emissions systems on your truck. EGR (exhaust gas circulation), SCR (selective catalytic reduction) and DPF (diesel particulate filter)
How Diesel Emission Systems Work
Curious what all those fancy, emission-related acronyms mean for your diesel truck? We explore all of them here.www.drivingline.com
No worries, it is my first diesel too so I have been doing all the research I can.Thank you for all the details,Owning a diesel for the first time will be a learning trend.
