45021 - 45027 of 45027 Posts
Fixed it!
I took apart the ECM and pushed the pins back into place. Reassembled it properly and it runs like it is supposed to. What a weird set of problems from those pins.
Reactions: dsmspick
Lmm
Rotated the tires
Greased the front end
Swapped air filters
full exterior detail starts this weekend prepping for my trip. Along with a oil change and trans spin on.
lb7
Installed a stack in it for my son.
2008 Silverado Gasser:
replaced my DS parking light bulbs up front and it still hyper blinks
swapped in new rears and it still hyper blinks
high beam bulb is new, even when swapping side to side the high beam will not come on for the DS
when using the DS blinker a small amount of light for the DS high beam is visible and the parking lights appear to be straining
I’m at a loss, have no idea what to check next
I don't have a guess as to what it could be, but I just wanted to say that I absolutely HATE GM electrical systems. That is all
Sent from my SM-G950U using Tapatalk
Lmm
Rotated the tires
Swapped air filters
lb7
Pics of stack? I used to have one in one of my LB7s. I think they sound the best with them.
Enjoy the read. This is from the start to now.
Install a resister and that should fix your problem. Local parts stores should carry them.
Sent from my Pixel 3 XL using Tapatalk
I finally got to drive my truck around today without my 20 ft enclosed trailer hooked up since installing EFILive last weekend. Setting #3 certainly added some pep to moving 8,000 lbs around. #5 will just wear out tires since I like to be out front when leaving redlights. Shout out to Brent at Lincoln Diesel Specialities for all his help!
Reactions: dsmspick
