1 - 10 of 10 Posts
What does everybody monitor on there Edge insight or CTS? I just picked up a insight and there is a lot to pick from.
When I do pick one up I'll probably have rail pressure and desired rail pressure.
I've got gauges for EGT, Boost, Transmission Temp, and LP pressure.
boost, egt, soot mass, fuel rail press, engine oil pressure, Mass air flow, Coolant temp, trans temp
Stock coolant and oil pressure gauges both inaccurate.
Boost ,Egt, tranny gear, tct, ect, voltage, hell I can't remember, change it around a lot.
Desired rail presure, actual rail presure, boost (read off obd port for now), coolant temp, oil presure, egt, gear+torque converter lockup, trans temp. And I switch between other stuff when I get bored😆.
I'm currently thinking about adding a boost sensor so I can read higher then the 23lbs the factory sensor reads, lift pump pressure via the bleeder on the factory filter head, and engine oil temp.
Reign in Blood
Boost, mph-c, fuel level, rpm, and engine coolant temp...my gage cluster is fubar Lol.
The next screen is my diagnostic screen...currently it has boost, mph-c, gear/tcl, Trans and engine temp, desired and actual fuel pressure, battery voltage, manifold intake temp, vp, and fuel temp. But based on what's going on it changes
Discussion Starter · #10 · (Edited)
There is 4 EGT options for the 2015
EGT post DOC/pre SCR
EGT post DPF
EGT post SCR/pre dpf
EGT post turbo
which one should I use to monitor and what is a safe temp.
1 - 10 of 10 Posts
