1 - 16 of 16 Posts
Hi everyone, thanks for reading. I'm pulling the engine and replacing head gaskets on my LB7. I found a couple "loose ends" and broken pieces on my way down into. Here's one...anyone know what this? It's a broken electrical connection/harness on the AC tubing, drivers side.
ImageUploadedByAG Free1417330581.433594.jpg ImageUploadedByAG Free1417330611.591132.jpg
Thanks
Looks like the high pressure switch.
Diesel Addict
That is correct, that is the a/c high pressure switch. James
I have one I think if you need it I don't know the cost on them let me know if you need it.
Thanks I definitely need one. I looked it up and its not hard to find the pigtail side of the connection, but as you can see, I think I need the housing of the switch (the female part that is connected to the AC Line).
Do I have to change out that whole piece of AC tubing from the compressor to the condenser? Or can I just change out the female switch portion on the tubing?
Thanks again guys....really appreciate your help.
You can just change out the switch but remember it will be under pressure if your AC system is charged
Good morning Ok I found the switch you need so give me a call or text if you want 9098161688. The line is under pressure but I do believe you can swap it without removing the refrigerant. Thanks Chris
Ok guys...I got that coming. Here's the next issue. What is this plug on the bottom passengers side block? I noticed a matching wire hanging under the truck a long time ago. If I remember right...this hasn't been plugged in for a looong time. Thoughts?
Could that be the block heater? Looks like it is in what would be a freeze plug hole if you didn't have the heater.
Sent from rapid typo device
Ya I guess so but would my truck have the wires for it just hanging down there even if the block Heater wasn't installed?
I doubt it. Check the looms down low on the pass side. I pulled my wire out of one to gain some more length. IIRC it was with a pretty beefy battery/ground wire.
Discussion Starter · #14 ·
I'll take a picture of the wire I'm talking about in the morning.
I know that it's surrounded by an aluminum insulation (almost like AC lines have). It's the only wire that has that shiny aluminum insulation around it
Discussion Starter · #16 ·
That's awesome. Thanks for the reply. I love in Southern California. If the lows are the 50s people freak out...I don't need a block heater.
1 - 16 of 16 Posts
