1 - 20 of 24 Posts
Found a little red switch in fuse box on inside any ideas?
· Premium Member
Probably for an aftermarket remote start. They normally have on/off switches for them.
Could very well be a valet switch for an alarm system…The ones I have had are mounted inside the cab in the fuse box right beside the drivers door….
How will I know what it does if it's a remote start how would it work all I have is stock door opener
· Premium Member
You need to find the alarm/remote start box under the dash and see what brand it is. Do you have any other antennas in your front windshield? It might be just a leftover switch from an alarm/remote start that they were too lazy to take out.
Im thinking when you flip it, it turns into a Prius. Gas saver switch
It's hard to see were it goes and could my stock keyless be a remote start?if so how do they do that
· Premium Member
there was no stock keyless remote start until the LMM engine in 2007.5 model year.
I turned it on nothing happens! Wires look like some go into engine some don't. Idk what is I know one of the green wires that goes into engine bay has nothing on the end
· Premium Member
well it could have been used for a high idle switch, but sounds like whatever it was on, it isnt installed still.
Do you have an aftermarket double din receiver with a screen and/or a slide out screen installed in the vehicle?
It could also be the switch to allow the screen to view videos/movies while in Drive. Just a thought..
I would say this is possible but unlikely only because it would really need to be reachable from the drivers seated position.
That would be a really inconvient spot for a smoke switch
Sent from my SPH-D700 using AutoGuide App
1 - 20 of 24 Posts
