1 - 10 of 10 Posts
Im looking into to getting a different turbo, although i dont know where to begin. Can i get a turbo without having to do a bunch of changes? Will i need a new tranny and a lift pump? What turbo would you guys suggest for mostly street driving?
If your goin to upgrade the turbo you should do the trans first. The turbo will do you no good unless you have the trans to put the power to the ground.
Edit: Your also gonna need a lift pump.
Stupid Has The Balls
Trans and lift pump. Then upgrade your tuning. Have fun with that....get bored eventually....dump more money on a turbo. Its how these things work
Like mentioned above to take full advantage of a aftermarket turbo you need a trans and lift pump. If you stock turbo is failing and you need a charger I would suggest a Garrett 4094vvt. They are a direct drop in replacement and only require oil drain gaskets for the install.
Tyler
MPF
Would i be able to just get my ally built up a bit or would i have to get a completely new tranny?
Call Tyler at mfp. Your gunna need a tranny though. He can set you up with everything
1 - 10 of 10 Posts
