1 - 7 of 7 Posts
I searched, but couldn't come up with anything.
My 08 has 24k miles, but the trans fluid and filter have 6 years on them; at what mileage/age does the filter or fluid need to be changed?
Thanks!
GM states the internal filter only has to be changed at overhaul. Many change the external filter the same as the oil filter. The filter is cheap at Allison-- $10-12-
^x2
You are likely fine, but you could go ahead and change the fluid to Transynd and change the spin on filter. Thereafter you should change every other oil change so somewhere ~20K miles.
My 08 also has 24,000 miles on it and I switched it to transynd about 2,000 miles ago when I did my transgo. The fluid wasn't bad and the Trans filters were changed every 6,000 miles. I changed the fluid just because of the age and that Allison recommends transynd over the dex that gm puts in them from the factory.
Can anyone tell me how many quarts the trans takes for a fluid and filter change? I just hit 30k miles and figured since it's 7 yrs old it would be a good idea to change it.
7-7.5 qts.
1 - 7 of 7 Posts
