I have Amp Research power steps and am having issues with the step fully retracting back when I close my door...I went on the Amp Research site and found this:
Concern: GM truck erratic step operation – Ground
Some owners of GM trucks equipped the Duramax diesel engines have reported
erratic operation of the Power Step. The corrective action is to move the Power
Step system ground wire from the 10 mm junction box mounting bracket to the air
conditioning support bracket bolt located behind the junction box. The resulting
improved ground signal path will correct erratic, unreliable operation
Where is the 10 mm junction box mounting bracket to the air
conditioning support bracket bolt located behind the junction box? I attempted to look for an '06 Duramax component layout diagram for a little bit.
The ground wire of the steps is currently on the bolt the secures the bracket that is labeled "Ground"...I'm thinking that it is already on a good ground but I just want to try what Amp Research advises to do before I call the motor bad.
