Are some better than the other?Every one that you pull up to.
If you can find a top tier diesel station. Basically none around my area. Will need to do a search in your area.Are some better than the other?
I heard Shell is better than Krist oil, ect?What’s “better”?
It‘s fuel, it all meets the same requirements. Some stations carry a “Gold” diesel that has higher cetane rating, but I’ve never seen any improvements using it.
Any brand name oil companies that you know of?If you can find a top tier diesel station. Basically none around my area. Will need to do a search in your area.
Various ones, but greatly depends on location. Check here, but ultimately it would be better to use a diesel additive like Hot Shots or Optilube in every tank.I heard Shell is better than Krist oil, ect?
my first Diesel fuel vehicle, just checking.
Truck stops might be a good place to start?I heard Shell is better than Krist oil, ect?
Truck stop diesel only excels in one area, being expensive, other than that it's minimum spec, and fine to use. Bio at percentages under 20 is decent fuel, as long as it's reasonably fresh, but you may want to avoid it in the winter months.Truck stops might be a good place to start?
ThanksB5-B20 supposedly is best for your fuel pump if you have a 2011-2016. And just so there's no confusion, it'll all be ULSD, that's been the law in the states for several years now. Agree on using the additives if you don't find Biodiesel in your area, even on top of the Bio if you like. There's no such thing as too much lube in these things.
B5-B20? Do they list this on the pump? If not how do I find out what it is?Thanks
I live in the upper Peninsula of Michigan, almost CanadaTruck stop diesel only excels in one area, being expensive, other than that it's minimum spec, and fine to use. Bio at percentages under 20 is decent fuel, as long as it's reasonably fresh, but you may want to avoid it in the winter months.
Costco's that sell diesel sell 'Top Tier' diesel.
Where are you from?
I’ve read most of the problems with CP4 are due to running crappy or higher Sulfur fuels, the additives help with Lubricity, to help lube fuel, which helps the CP4. Cheaper than replacing the pump.Like I said, every station that has diesel it will be ultra low sulfur diesel, every one. That is required by law to be used in Diesel engines.
I recommend biodiesel. I’ve been running it for as long as it’s been a thing and it’s been great. Never had water in fuel issues or a CP4 failure. I think the stuff is great.
Personally I have never run a fuel additive, I think it’s a complete waste of money. I’ve been running Duramax trucks since they came out and have never run an additive and have never had a single fuel related issue ever.
