I'm getting ready to install my Aeromotive lift pump and plan on using the standard issue fuel pump relay and OPS safety switch. Where is an easy location to tie into to get switched power? I'm hoping there is a lug in a fuse panel that I can put a spade fitting on?
There is definitely a switched spade in the box down by the footrest. I can't for the life of me find a diagram showing which though. I believe (from my recollection) that it is towards the center.
do you happen to have a circuit tester?
Yes I do. I'll take a look in that fuse box and see if I can find it.
Shouldn't take you very long at all in that case! Good luck with it, let me/us know if you have any questions :thumb
Bottom left of fuse box as you open the door there is a little male spade sticking out that is key on power
