Driving along quite happily, engine cut out.
Probably lack of fuel, the gauge wasn't showing empty but it's the lowest I've run it so I'm assuming the gauge is reading a bit high
Switched to reserve tank, plenty of turning over but no hint of starting.
I'm guessing the fuel pump needs priming (sound right?)
The problem is finding it, I've spent about 4 hours looking for the fuel pump but there's so many pipes and wires covering where I think it is I'd like some idea before I start dismantling stuff in the wrong place
It seems obvious - follow the injectors to the common rail, then the pump, easier said than done in this engine bay.
I think it's top, passenger-side of engine, there seems to be bosch injection stuff there but I'll have to do some serious dismantling of intercooler, air inlet hoses etc to get at it - and I'm not certain it's there anyway
Anyone have any diagrams or pictures of exactly where the priming pump is located?
I don't have any manuals (and no idea where to get them although I'd welcome suggestions)- there are no GM workshops here - the truck is stuck a few miles away and I need to get it home
Am I right in thinking it probably needs priming?
Any ideas where the primer pump is?
6.6 Duramax, probably new in 2005
