1 - 2 of 2 Posts
I have the need to replace tie rods on my truck and I want to upgrade. I would like some feedback on which route I should go... two options on cognito site are 2001 - Present GM 8-Lug GM Heavy Duty Tie Rod Steering Kit or Cognito 8Lug OE Style Heavy Duty Tie-Rods.
Which is the best way to go?
Do I still need tie rod sleeves with the Cognito 8Lug OE Style Heavy Duty Tie-Rods?
Should I replace the center link at the same time?
I am also putting on Moog idler and pitman arms when I tear all of this apart.
Any feedback is appreciated....
Thanks Guys/Gals
like a Ninja
with cognito HD tierods you will not need sleeves, there already massive as is. since youre doin pitman and idler arms you could install the braces to help prevent wear and tare on them so theyll last longer. ill send you a PM...
1 - 2 of 2 Posts
