1 - 20 of 91 Posts
Just Bought a 07 LBZ 4x4 and its my first Diesel. :rockin
It has a Bully Dog RFI Intake and thats the only mods.
Truck has 67,000 miles has 285's
saw what you did there
Thanks for the help, so what should be done first Exhaust or programer?
Exhaust for sure. It is cheaper and when you do get the programmer you will be able to keep your EGT's down.
Discussion Starter #6
With my LBZ, Which type exhaust or brand and will it throw codes?
I don't think you'll throw any codes, diamond eye, mbrp, silverline, they're all kindanthe same in my opinion. Aluminized steel is fine. .02
Discussion Starter #8
One last thing will i have any problems with inspections. In Louisiana in the parish that I am in they plug the truck into a computer for emission test.
If you don't have any cels, you should be good. Do they do a "snap test" down there?
Discussion Starter #10
Any cels?
Cel=check engine light.
I don't think straight piping a lbz will throw any codes, but I'm not sure, hopefully so done can chime in and verify.
Discussion Starter #12
I am picking my truck up friday and have about a 300 mile trip back. Then im going to find a local shop to put the pipes on and probably go head and order a tuner, i'm liking the Edge Evolution as of right now, then looking in to a in-dash dvd. Easy spend money on these trucks im learning but its a addicting!!! :):D:)
It's everything I can do to not spend, spend spend! Congrats on the truck!!!!
Steve
Discussion Starter #15
So the Exhaust turbo back or just put a High flow muffler, I have been talking to some shops and getting mix messages! What the impact or both or is there another system?
2500HD Club Member
Do the whole exhaust, just a high flow muffler wont do much on the stock exhaust
Discussion Starter #17
Did you have to "Fingers Stick" and Blocker plate to get the codes strait? Btw pictures coming soon of the Truck!
factory truck has either a 3 or 3.5 pipe need at least a 4 to really get the power rollin. good luck on the downpipe i didnt replace mine bc i was told it would require lifting the cab off the frame and that sounded too much like work lol.
who told you that? :rof
it's not a easy install, but you certainly don't need to take the cab of the truck dude.
Discussion Starter #20
Well i found someone who will put a turbo back on and take the cat(i think out) for under 300.
1 - 20 of 91 Posts
