1 - 7 of 7 Posts
Is there a way to test the 9th injector....easily?? In the last few weeks I am getting a lot more white smoke coming out the tail pipe when I get on the throttle. I’m used to seeing it during regen every 500’ish Nile but now I see it every couple hundred miles. Only happens when I get on the gas pedal hard. Nothing when I am going slow, stopped, or a slow constant acceleration.
Other factor that doesn’t have me real concerned is after 1000 miles from oil change I was around 1/2 - 2/3 quarts low on oil. Typically I add about 1/2 quart of oil around 3-4K Miles and sometime none after 5k miles. I need to watch this for sure. Same oil I’ve been running for a year. I have been towing a lot recently too and stuck in a lot of traffic so the oil thing could be a mix of variables I get that too
Discussion Starter #2
And I used about 3.5 gallons of DEF in just 2000 miles. A little more then normal but towing and traffic will use some extra but never that much in my experience
White smoke usually indicates a blown head gasket and coolant in the exhaust. Even when I had a bad NOX sensor and DEF consumption skyrocketed there was not a visible change in the exhaust.
How cold is it outside? How long do you let the truck warm up. It's pretty common to see smoke with cold fuel.
Discussion Starter #6
I’m in CA so the mornings here are in mid 40s. I usually use the remote start and let it heat up (at least heat my seat up) for 5-10 mins in the morning before I get going.
Just wondering if Stanadyn switched formulas or something. I have been using the lube forever on this truck. Sometime if traveling in mountains in the winter I use Optilube XPD for the cold protection and it does the same thing (blowing so much smoke). That’s why I stopped using Optilube throughout the year.....hmmmm I wonder.
You can go buy an edge cts insight monitor, to watch engine parameters. Tells weather or not the truck is in regen. But those run I'm thinking 400 bucks.
I haven't bought fuel in California but buying in other Western States I been having the problem of truck smoking when trying to regen. I think it's the source of bio fuel used out there. It doesn't produce enough heat/staying burning in the exhaust.
1 - 7 of 7 Posts
