Will they rub only when turning sharp, or all the time?they will fit,but just like he said you will have some slight rubbing..mostly on the front lower valance though,I removed mine for the Ranch Hand but they are easy to trim with a jigsaw or dremel tool...
Thanks, Boone!Mine only rub when you turn sharp on rough ground.
Mostly when backing AND turning sharp!!if you dig in the threads a while you will see some trucks running this size and also how the owner's trimmed what was rubbing..:drinkWill they rub only when turning sharp, or all the time?
