wiring Halo Headlights
7.8K views 5 replies 2 participants last post by  Bmax05
I got a pair of Halo headlights for my truck,but I could'nt figure out how to wire up the halos. The wires were'ny color coded and there were no instructions in the box. any sugestion would be appreciated.:help
#4 ·
The two red wires are the ones that need to be spliced, directly out of the headlamp the wires are red and white (2 pairs) then they run into a harness and the into 1"x2" block where they splice into the pair of red wires.
I dont think it matters which red wire you use comeing off your halo. Both my halo wires are white and when I tested the halos I just hooked each wire up to my battery and the halos came on. I reversed the white wires and my halos still came on. No need to splice onto the factory wires. Take the 2 halos wires and splice or solder (preferred)them on the parking light wires from your headlight assembly. That way you just have to plug them in
Ok thanks, when I got the lights I tried testing them and neither wire activated the halos. So
maybe they are blown.
