I have a 2005 Duramax 2 wheel drive 2500 hd.
My trailering wiring is going whacky.
When I activate my right turn signal the 4 way flashers activate on the trailer but the signal works properly on the truck.
I had the truck checked and the trailer is NOT causing the problem.
I have an appointment at the dealer Tuesday Morning but I was wondering if anybody has also had this problem?
The rv dealer here checked the wiring and the plug on the truck and both fuse panels(under drivers dash and under hood) read 4 way flasher activation somewhere in the trailer harness.
Is there a relay or diode I can swap out to fix this problem? My local GM dealer charges$95.00/hr to diagnose electrical problems.
