Legally speaking........
It is my opinion that the Wix 33960 has a problem with the inner seal.
The 33910 (NAPA 3910)was the forerunner to the 33960 and was manufactured by Raycor for Wix and had a thick compression inner seal so that when the filter was restricted, the seal was maintained and the engine lost RPM at any speed.
The 33910 was replaced by the 33960.
The 33960 is manufactured by Wix and has a different, much thinner, non compression, lip seal that allowed unfiltered fuel past the seal when the filter became restricted. Idle was the only time restriction was appearant. At highway speeds when the filter became restricted, the CP3 pump was strong enough to pull unfiltered fuel past this newer, thinner, less effective seal and the engine was able to run at higher RPM's. At the time, I had 500 miles on that run with an auxillary tank which allows for coast to coast travel. I became aware of the problem only when I pulled into a rest area and the engine idled down below 1200RPM. At this point I have one engine where the injection system has been compromised. Unfortunately, it is an expensive fix for an inexpensive product. This has happened twice. The first time the filter was replaced before any contamination caused a problem and I didn't catch what was going on. The second time I didn't catch it in time.
Wix has been contacted.
This is not meant to be a slight against Wix or anyone selling Wix products. As some of you know from my previous posts, I have been a big fan of Wix filters and have used them for many years, but it appears that they have a serious problem with this particular filter.
The filter had 3000 miles on it when this happened. I normally change it every 5000. In over 40 years of automotive experience including running a shop, I have never encountered this before.
