1 - 11 of 11 Posts
I'm hoping someone can give me some insight on a reoccuring problem that I am having with my 2001 Duramax. For the past 10 months I have had an issue with the engine not going above 2000 rpm's. This happens both in summer and winter temperatures and it is not consistant. When I first had the dealer look at it they said that they needed to replace all of the fuel injectors; fortunately it was covered under warrenty. The problem continued so I brought the truck to the dealer again. This time they said it was the turbo boost sensor so I paid to have that replaced. It did not solve the problem. Does anyone have any idea's on what the problem can be?
Diesel Addict
i'm not sure what the problem is but on my 05 lly when i run it to hard it does the same thing,if i'm not mistaken it has something to do with fuel rail pressure,buy a new fuel filter that should take care of the problem,fixed my truck plus i have a programmer when it does it then i just reprogram it
_____________________________________________
[SIGPIC][/SIGPIC]
05 lly dually mods,the mirrors off my 06 2500HD,programmer ppe hot soon to be upgraded to the hot e.t. 2:fart ,ppe boost controller,S&B air intake,dual 4" siverline turbo back exhuast with 5" tip no cats,bully dog shift kit soon to be upgraded to stage v sun coast transmission with triple disc torque converter$$:gearjamin,wish list:teasetwin turbos,dual cp3 fueler,bigger injecters,and so on$$$$
Thanks for the reply. I also thought the fuel filter could be the problem but it wasn't; I had it replaced and still had the same issues. When the injectors were replaced, they also replaced the fuel rail.
Diesel Addict
did it take care of your problem?
[SIGPIC][/SIGPIC]
Diesel Addict
have them check the lift pump,fuel pump and fuel lines.p.s. just a thought if the fuel isn't getting to your fuel rail fast enough it wouldn't have enough fuel rail pressure
[SIGPIC][/SIGPIC]
Diesel Addict
my bad i should have known that.
[SIGPIC][/SIGPIC]
Hi, I'm Earth. Have we met?
if a new filter didnt fix it i would look at trans slipage, it will cause limp mode also!! When it dose it find a garage u trust to read the codes this will help a bunch!!
Good Luck
Caleb
Did you ever have the spin on trans filter changed?
I had the same problem last year. It was due to a blocked fuel filter due to puting in some bio-diesel from a truck stop that had just changed to it and the bio-diesel actually cleans out the old storage tank and pumps the trash into your tank. So, try getting your fuel from another source if you only get it from one location.
Thanks for the suggestions. I have not yet tried bio-diesel and I'm not consistant with filling stations. I also thought the fuel filter would be the problem but changing it did not solve the problem.
It hasn't acted up in last few days so I'll keep my fingers crossed and hope for the best. I do plan to bring it back to the dealer that changed the boost sensor so that they can check the codes. They assured me that they would make good on the issue.
1 - 11 of 11 Posts
