1 - 8 of 8 Posts
Help! Won't shift!
I just installed a trans go Jr. kit. I thought everything went will, but it will not shift higher than 3rd gear. Annual ideas on what I did wrong? Shift fine into reverse and drive.
do you have any little balls left, may need to check if they are in correct positions
I think so but taking it apart now. Seems electrical, shifts fine until third.
Well i dont no what the symptoms would be if the solenoids were backwards but make sure they were put in the same places that they came out of. i have heard of this causing issues.
I soldered the wires back to the clip and all is working fine. I missed the top clip when I removed the valve body and must have pulled one wire wire off. I think I did a good job with the soldering, will this hold? Or should I still get a new harness?
1 - 8 of 8 Posts
