1 - 20 of 23 Posts
Has anyone come up with a workaround for the auto stop/start yet? It is becoming increasingly annoying when I forget to hit that button...
Put your trans in L and go to the highest gear. My father has to do this on his Traverse too...
I didnt realize this was a thing on the babymax
Not really pertinent here but I bought my wife a Buick Enclave back in April. That damn thing doesn't even have a start / stop disable button. You CANNOT turn that crap off. It drives me NUTS every time I get in that car and I think it has stalled out. Wonder how much longer that disable button will be available in even the diesel models.
2007 GMC Sierra 2500HD SLT
My work truck is an F150 with the auto stop/start and the only thing I've found other than having it programmed is to plug in a blank trailer harness into the 4 pin connector. It thinks I'm pulling a trailer but at least the stupid thing doesn't shut off at stop lights
Auto Stops may not occur and/or Auto Starts may occur because:
. The climate control settings require the engine to be running to cool or heat the vehicle interior.
. The vehicle battery charge is low.
. The vehicle battery has recently been disconnected.
. Minimum vehicle speed has not been reached since the last Auto Stop.
. The accelerator pedal is pressed.
. The engine or transmission is not at the required operating temperature.
. The outside temperature is not in the required operating range.
. The vehicle is in any gear other than D (Drive).
. Tow/Haul Mode or other driver modes have been selected.
. The vehicle is on a steep hill or grade.
. The driver door has been opened or the driver seat belt has been unbuckled.
. The hood has been opened.
Tow/haul mode or trans not in D will work.
I find it about as simple to push the button....
Sometimes I just lift foot on brake enough to get a restart and then press brake again.
(since it won't do another stop until the minimum speed has been reached)
Reactions: jblather
Interesting.
GMC Acadia (2021) has a button for it.
Acadia / Enclave are not the same layout, but on Acadia it's a button on the console ahead of the cup holders.
I find the restart less annoying on the Acadia than on the LM2 but I still usually shut it off.
If the truck is 'off' for just the right amount of time, the iDash (data logging version) will shutdown and not restart. Probably a setting that can be changed, but haven't gone back and reviewed the set-up.
There is it's $99. I'll paste a link below. I haven't installed this nor do I personally know anyone who has but I think I'd like to. I forget all the time when I drive the truck.
Auto Stop Eliminator
I put it on mine a week after I bought it, love no longer having to deal with this feature, well worth the $99.
{ just hit that button as a matter of habit when I get in, Thank goodness it is handy and not buried in the infotainment system, or not available at all, like some vehicles.....
Reactions: 98whitelightnin
On a Ford there is a small plug to the left of the brake pedal you can unplug and it won’t cut off. The Module is to the left of the brake pedal and the plug you remove is the small one at the bottom. It makes the truck think there is a trailer hooked up all the time. It’s literally a 10 second job.
Reactions: jblather
Another thought.
Does the Tow/haul disable it on the Enclave?
This ^^^^^
Another thought.
Does it even have tow / haul? I don't know, I almost never drive it but even when I'm just riding in it it drives me nuts.
Interesting.
It's possible I missed the button but I read the owner's manual looking for a way to disable it - a disable button is absolutely not mentioned.
I downloaded the Enclave OM pdf.
It says there may be is tow/haul. (trim/option level?)
I didn't see mention of a disable button either. (but of course it might still have one...)
If it is equipped:
MODE
Automotive parking light Car Vehicle Automotive tail & brake light Grille
To select the Sport Mode or Tow/Haul Mode, press the MODE switch on the center stack.
Pressing the MODE switch will display options of all available ride modes in the DIC and change to the next mode.
Subsequent presses will scroll through the available modes.
Dont you have an L option on your shifter? Then + and - buttons?
If it is equipped:
MODE
I'll look for that. It may have it. It's not the butt-scratcher edition, it's leather and all that but not A/C seats and all the cameras and such.
Thanks.
1 - 20 of 23 Posts
