Would you buy a LML
55K views 58 replies 31 participants last post by  knits4him
Would anyone advise against buying a LML due to the CP4 problems? I'm looking for a truck and was just wondering what people think about this. I have read that 2017 and newer have Denso injection pumps so the CP4 problems must be real and not just a very small number of failures. I have also read that the CP4 pump was improved in 2014 but I haven't been able to find anything definite on it. Any comments would be appreciated. Thanks.
#4 ·
No doubt there are thousands of CP4s with a ton of miles on them with no problems. My personal experience, I have four friends with LMLs and two of them have experienced failures. A 2014 at 50k and a 2015 at 75k. I would only buy one with intentions of a full delete and CP3. Otherwise just save up for a L5P.
Seems like these LML’s get the bad rap like the old 6.0 power strokes. I wouldn’t be afraid of buying one. Is it on the back of my mind that could have a catastrophic failure? Yes, but not going to trade my 50K 2015 off because of it. I just make sure I use an additive every tank and keep filter changed when computer gets to 50% life (which is usually well over 10K miles). I personally only know one guy that has ever had a HPFP failure with a LML and it was an hot-shotter. I know there are many that have had failures but it’s still a very low percentage, probably <5%. Keep in mind they made hundreds of thousands of LML’s between 2011-2016. Something to also consider is when the L5P came out they took quite a jump in price. I know a new 2020 spec’d out like my current 2015 is at least $6K higher in MSRP compared to the 2015 MSRP. Some of it is technology and annual price increases, but biggest part is the powertrain.
treat your truck the way it should be treated and it will take care of you .. if you drive the shit out of it it will shorten it's service life. i love mine and it is at 115K with no issues. i tow a 42' 5th wheel 8 to 10 times a year the rest of the time it's my daily. used it this morning to kick a little hot rod Honda's ass at a red light but most of the time i just drive it normal
#7 ·
Yes. I once said I’d never own a lb7 or an lly but here I am having had all but an lmm and l5p. They have all been pretty much trouble free.
I had mine from 40,000 miles to 100,000 miles. Only issue I ever had was the TCM. It was 1,000 to fix. But I put the truck through it’s paces. I’m going to buy another one next year if I can find one with under 100,000 miles and under 25,000.
#10 · (Edited)
I have never been happier with a truck purchase than I am with my LML ( 2013 bought at 80,000 miles; now approx. 93,000 mi.).
It does everything expected of it so well. ( primary use is towing my "toy" trailers - one is our three axle boat trailer, the other is my "box" / hobby car trailer - both "bumper pull" of about 1,300 lbs. load on the hitch - each weighs approx. 11,000 lb). Ocassional use as a "2nd car").
I am especially impressed with its ability to handle the meanest long up-hill grades on I-40 here in the high country of northern Arizona, combined with its ability to handle the extremes of temp. out on the Mojave Desert in the summer.
Yes, to get it the way I like it meant I treated it like a "do-it-yourself" kit...meaning did the CP-3 BEFORE a failure, air shocks with one spring leaf removed, to give a better more controllable ride.
To insure no problems with the DPF, plan on having it removed from the vehicle, cut apart, and PROPERLY cleaned, oh...say at 100,000 intervals ( at one of the facilities that does this for the DPF's on the big OTR trucks - I personally believe the "forced regen" that becomes necessary from time to time is hard on the truck).
If you live like I do in a "non-inspection" area, you might consider certain "parts relocations" that will result in your engine oil staying cleaner, and your fuel mileage improving by at least 3 - 5 mpg, and no more of those weird harmful "on road" DPF cleaning cycles.
Just remember that Greta Thornberg will hold you personally responsible for ending life here on Planet Earth in only the next 7 years, AND you will be held personally responsible for the deaths of all those cute little fuzzy chinned bunny wabbets.
Should you decide to "fix" your truck so as to become a murderer of the cute little fuzzy-chinned bunny wabbets, & want to deprive Greta Thurnberg of her childhood......bear this in mind - the "ecology freaks" are becoming more politically powerful every year.
So save every bolt, nut washer, gasket, etc. along with all of the hardware that came with your truck when new - it is possible in the future we MAY have to put all that stuff back in order to re-register our trucks.
There was a bill in Congress last year that would have turned our entire country into an "inspection" zone...it failed. This time.
Reactions: knits4him
#11 ·
It would be interesting to see an actual failure rate on the CP4 pumps. I have heard in reality it is 10% or less but I have no factual data to prove it. When you consider the hundreds of thousands of these vehicles that run around the country every day, not only the Duramax's but the powerstrokes too what is an actual number of failures? Does it truly warrant the negative stigma? I would imagine if you look at the rate of failure of owners on forums, its possibly higher given people on forums are usually looking for advice on DIY repairs or modification. Hell hath no fury like a truck owner scorned.
I purchased my truck knowing full well what that little thing is capable of doing, but I'm taking care of it. Keeping water, air and contaminants out of the fuel, keeping the tank full, fueling up at popular stations that don't sell budget fuel, etc. Going to add a lift pump here before camping season just to make sure.
Another thing to keep in mind is the fact that there may always be a sentence missing when people talk about losing their CP4. Perhaps they have been fueling up at discount stations, maybe they let that fuel filter go 20K (hey, it ran great yesterday right?), maybe they start it up and hammer down cold, or constantly run around on half a tank or less, running the tank dry, or cranking it over too long. All of those things are factors to any diesel engine component failing. I know a guy who bought a brand new L5P and hates it. In less than three years, its been in the shop 6 times for emissions issues. Even left him stranded on the side of the road on a family vacation.
Just about every truck is going to give you some reason not to buy it.
#12 ·
Everyone speculates about the failure rate, but in my previous post I don't see how it can be more than 5%, probably more like 1-2%. If it was 10% then 1 out of every 10 LML's going down the road would have failed and there is no way that happens. The dealerships would literally be backed up with them with how many LML's were built and on the road. To me the bigger issue is the cost of repair. A couple thousand dollar pump can cost you 5 times that in repair which is absurd in my opinion. GM knows they have a problem. I think they should offer some assistance on this repair (maybe not the whole amount) for some extended time somewhat similar to what they did for the injector issues on the LB7. There aren't many of us that can afford a $10K+ repair and downtime especially if running a business. Or at the least offer some type of extended warranty or insurance coverage specifically for a pump failure.
#14 ·
2013 with 135,000 and no problems. Pretty much stock accept for dpf delete and egr block off. Primarily did those things just to avoid having to purchase a new dpf when that one plugged up for good. I've had the truck since new. Delete over 20,000 miles ago with no issues. I do run PS addative with every tank.
#39 ·
2013,...…. Primarily did those things just to avoid having to purchase a new dpf when that one plugged up for good.....
NO NO NO ! No such things as a "DPF plugged up for good".
True, GM has designed our "consumer grade" systems so you get to pay almost three thousand dollars to replace it - on some years the entire exhaust system from the back of the CAT, thru the DPF, all the way to the tail-pipe is ONE system (which, incidentally, was installed at the factory before the body-drop so you have to cut it up in sections to get it out/service it.
And yes, there will come a time when even a stationary "forced regen" wont (PARTIALLY !) clean it so your limp mode code can be re-set.
Get real - you think the big OTR boys would tolerate having to throw that thing away? Of course not. that is why in every major city you will find businesses that service DPF's. The trick is finding one who will bother with "consumer grade" trucks. In my case it was just under $800 to PROPERLY clean the DPF. They cut the thing out of my truck, cut it open, PROPERLY cleaned it, welded it back together, re-attached with "quick-disconnect" fittings so next time easier to service.
#15 ·
One of my biggest regrets in vehicle buying and selling was getting rid of my 2015 GMC Sierra 2500 HD with LML. That was the most flawless vehicle I ever owned. I think it had 65K miles on it when I traded it because my accountant said it would be a good idea. Got a 2018 L5P that was nothing but trouble and finally convinced them to take it back. Got a 2019 and it hasn't been as bad but still bucks like a bronco at times with shifting being all hosed up. So needless to say I miss my LML.
#16 · (Edited)
i need to just make a macro to copy and paste this since it comes up so much.
forums consolidate like minded people, in this case, may of the people here came here seeking help for a problem. So forums are kind of like the spiraling drain of bad news since people are coming here to talk about this failure and see info on it, but people with perfectly working trucks are not posting "still running" posts. This skews peoples perception of the problem beyond what it is.
That said, even with this inflated value, this forum in a poll of 600-700 people if memory serves showed a failure rate of 8 -12% over 100K miles which while higher than i would like, is far from the eminent time bomb people make it out to be. This percentage is significantly higher than what would be sampled in real world data just due to the nature of the forum. I would guess the actual rate is under 1%.
The pumps are likely failing due to a few factors that have been discussed in great depth on this forum elsewhere. Basically it comes down to fuel quality over anything else. The CP4 was designed to run european grade diesel which has higher lubricity than US diesel. This is due to the sulfur removal process, but not the sulfur itself. so now you have a pump running fuel as lubricant, that does not meet the manufactures spec for lubrication. Already not off to a great start here. There is some evidence also to support that a lot of the fuel filters on the market are no where near as good as we expect them to be, so your choice of filter may be allowing water and other contaminants into the pump that you would assume are captured. This also adds to wear.
Basically, if you run quality diesel and dont shop for the cheapest pump in town, and you use an additive to increase lubricity (optilube is good by forum opinion) and change your fuel filter regularly with a good quality filter like the AC Delco, your odds of a failure are very low, and due to the fear people have of the pumps blowing up, the trucks probably a steal. I know mine was.
A first generation fuel system is not necessarily better. There has not been sufficient time on that system for any major issues to show up, so it might be better, it might be the same, or it may even be worse than an LML, we dont have enough data yet.
#51 ·
ARE WE TALKING ABOUT AN AMERICAN MADR VEHICLE THATS MANUFACTURED TO RUN EUROPEAN FUEL 🤔
#18 ·
I bought the first year 2011 new. During the first 5 years all 8 glow plugs were replaced, 1 at a time, 3 fuel injectors, fuel filter housing, TCM and parts of the DF system. And one of the wheel sensors for the brake system. I've got 70,000 miles on it now and I've only put 1 set of tires on it and still have the original brake pads. I replaced the driver seat cover with an oem replacement. My bony ass wore it out.I like the new ones but I can't justify spending 40-45,000 bucks for a new one when mine is doing great. I''ve got a long way to go before I will need a replacement.
#19 ·
Mine is a 2014 3500HD Silverado with 121k miles on it. What has been done since new? Replaced NOx sensor, replaced DEF tank, and just had Radiator replaced (pinhole leak near bottom passenger side)
It will regen every 700 miles or so. When it gets 40grams of gunk in the DPF filter. Just get out on the interstate, put it on 70, and 30-40 min later it’s done.
GM mechanic said likely the only thing I’ll see before 200k miles is the water pump, but it’s fine right now and he didn’t see anything else to be concerned about.
Most irritating thing is the radio display gets flakey.
No fuel additives and no mods. I keep the tank full and refill when below half, and I’m mindful of where I fill up.
So if you’re used to a gas truck and zero service issues before 150k miles, then you might be bothered by the fact that diesels will have more issues. But all in all, just nitpick things gone wrong so far. $500 nox sensor, $1500 def tank, and $1500 radiator, all covered under warranty.
I would buy it again.
#20 ·
I bought a New LML in 2011, drove it for 115K miles before trading for an '18 L5P in Jan of 2018.
Most of that mileage for towing 3 different Fifthwheels, 1st approx 14K, 2nd 17K, now 19.5K total mileage towing was approx 100K.
Had and EGR Cooler issue when still under warranty and had the bad Nox sensors replace, other than that never to a repair shop.
#21 ·
I just turned 169,000 miles on my stock 2012 LML. I've had the DEF tank heater problem, replaced under warranty.
I've replaced one glow plug, and the #1 Nox sensor. No other problems.
I use Baldwin filters, buy from a quality fuel source and use a lubricity enhancer. I'm changing oil & filter (synthetic) at 5,000 miles, and fuel filters at 10,000.
I did install a Wherli FPR as a precaution against a CP4 failure, a modest investment for the protection it provides.
I've run the truck from NH to AK carrying a 4,800 lb. truck camper, a use it to tow a 36 foot 5th wheel all over the US.
Except for the misguided EPA mandated emissions system, this is the very best of many trucks I've owned. I plan to operate it for many more miles.
#22 ·
Here's a question for the group; is a DPF removed and CP3 converted LML the penultimate reliable and durable modern diesel? Taking into consideration the vast improvements to the chassis and suspension coinciding with the introduction of the LML, the addition of the diesel exhaust brake, and the stout and very well programmed Allison 1000 transmission (that has now been replaced with a GM made 10 speed). LMLs are largely a beefed up evolution of the LMM, but with stouter components to handle greater power; seemingly the only weakness being added in the CP4 that was used to meet tighter emission standards (Also used on the 6.7 Powerstrokes. Thanks for ruining every part of our lives leftist government).
I have a 2011 that is my weekend truck. I own it purely to tow a travel trailer or equipment trailer. It is a weekend truck for me (daily driver is a '19 1500). I own it free and clear and it tows amazing and gets good fuel mileage. The only thing on my list left to do to it is a CP3 conversion to cement it's reliability for the long haul. The approx. $4k investment is a whole lot less than buying a new truck.
#24 ·
well, the LML is a good truck, but like every other truck, when you fix one previous generation issue, something else slips through the cracks, so no truck is perfect. I will say though that the LML is a good truck, with lots of features and power. When you fix one weak link in the chain though, theres always another weak link behind it waiting to show up. In the case of the LML its probably the pistons and or rods. I dont want to say they are known to fail, but you do see more posts about cracked / melted pistons and shrunk rods on the LML than any other duramax.
In therms of the delete question, you can put a CP3 on without deleting it and that would resolve your concerns about the pump, but this will run you about 3 grand installed give or take a bit. The emissions system is still a weak point, but given the recent events with the EPA crackdown, i cant really tell you that deleting is the answer, since the EPA may make that totally not an option at some future point, as is you can barely get the parts to do it.
Lastly, every duramax with a variable geometry turbo has an exhaust brake, it just needs to be enabled on the older trucks. Its a really easy mod to do, so if thats the selling point, id go get me a nice 06 07 classic and nto worry about the urea or pump.
#25 ·
This was something I deeply considered before buying my LML. If it were to fail I really don't know how I would pay to get it fixed, I don't have a spare $10k laying around. My truck is a 2015.5 with 112k miles so its out of warranty. I do plan on CP3 converting it probably this spring or summer, until then I make sure to run quality fuel and use additives to hopefully get me by until I can swap it. I love this truck but the thought of the CP4 going is always in the back of my mind :(
#26 ·
I’d buy another one. My 2014 has 105k on it and I pull a 12k lb toy hauler and a snowmobile trailer through the Rockies on a regular basis and it runs great. Much better / stronger truck than my 08 LMM for sure. I run fuel additive, a filter magnet and a Kennedy lift pump keeps the fuel pressure positive all the way through the system. Stock emissions and tuning. Just about everyone I know that has tuned, deleted etc has problems so I refuse to do it.
Also, who’s done the money math on replacing a CP4 on a $35,000 LML vs dropping 60-80k on a newer truck?
#27 ·
CP4 is not the only LML weakness. I'm surprised it took until post 24 before the pistons were mentioned. Beware of big tunes.
If you're cognizant of the weaknesses and take appropriate measure to mitigate the risks, you can definitely get good service out of an LML and they can be a good buy nowadays. If you get one that likes to have emissions issues and you're not able to or not willing to delete it, you'll hate it. Constant emissions problems will pretty much render an LML useless as well as very expensive to keep on the road.
If you find what appears to be a good one and you want it, make an offer. If it's at a dealer, lowball the hell out of it. I had a friend trade off a nice 2015 Denali dually last year with 170k miles on it and they stole it from him, and it had a complete new fuel system on it including its fourth CP4. You know that dealer put it on the lot at full book retail value. I'm sure a guy could have owned it for $10k under book.
When I looked at trading mine off last year, dealers around here wouldn't even talk to me. I listed it on Craigslist under book and never got a call. I know it's a buyers market around here now on LMLs.
#28 ·
All the reading I've seen says that LML pistons are stronger than the LBZ/LMM pistons. But I'm also seeing people say LML pistons are weaker. You would think the LML pistons would be a bit better as they made a bit more power vs the LMM from the factory.
#29 ·
I bought my 2013 lml in November of 2013 so good deals cause 2014 was body style change so I did it. 1000k later I put a fass 95gph lift pump and a s&b cold air intake. Drove it till 65k with no problems and used fuel lubes whenever I remembered like maybe every 4-5 tanks. Only problems I ever had was the typical TCM failure and my input shaft seal on my trans was leaking but not bad so I waited till my aux port in my radio failed and they fixed both under warranty. I tow a 22 foot pontoon boat all over Colorado and Nebraska and I have never had a lick of problems. At about 65k I finally put gauges in it to monitor my egt's and fuel pressure from the fass and my boost. Then I started babying it cause of my high egt's and I read about the piston failures but before the gauges I know I pushed her harder than that. Then i traded it in for a 2020 l5p with the 10 speed (yes the ugly one and i love it) and it was the wife's idea so who am i to argue lol. Colorado has adopted California's emissions laws so i couldn't do with it what i wanted to anyways. But never major problems and I am hoping this new truck doesn't make me regret trading it in. I would not be hesitant on buying one they are awesome. You take care of it, it will take care of you.
#30 ·
I bought a new 2016 LML 4 years ago knowing about the CP4 issue before buying it. I shopped the Fords and Dodges 4 years ago and still went with the GMC. Back then the Ford and Dodge were a lot cheaper than the GMC but I shopped so long GM finally made it worth my wild to buy the truck I wanted with incentives. No regrets.
