Vendor
The XDP WIF Sensor Delete Plug will remove your OE Water in Fuel Sensor. Over time the problematic factory plastic sensor can become damaged. This can cause error messages, fuel leaks, air leaks & even hard starts. Eliminate all of these problems before they leave you stranded! For ease of install the XDP Delete Plug can be installed with a 3/8” Ratchet or with an XDP/ Aftermarket WIF Wrench. Made in the USA!
XDP Duramax WIF Sensor Delete Plug
So this plug will not throw codes? How will I be able to monitor if there is water in the fuel? Will I still be able to drain excess water?
Well that seems too simple lol
