Well, you still need to buy a TCM, the column shifter, and associated wiring harnesses. Does the allison come with the torque converter? I hardly think that you can get an allison that doesn't need a rebuild for less than buying a clutch....how much are you looking at spending on a clutch? I think all being said and done, it will be cheaper to change the clutch than to get everything needed for the conversion.
