110v power outlet dead. All fuses are good.
13K views 5 replies 4 participants last post by  CharlieATX
Help!
My in dash 100v outlet stopped working around 65,000 miles. Until then no problems and I'm not aware of anything unusual happening.
I have always (and only) used it to charge my phone. The USB and cig lighter outlets all work fine and still provide power.
A Chevy dealer looked at it and could not determine the problem. They checked, all fuses were good. Later, I also looked over all the fuses and all good. I pulled the APO/RAP fuses to get a close look. All good.
So, what could be the problem? (Hint, not a fuse.) Anyone else seen this?
Thanks.
2016 3500 HD LTZ
Power Inverter went bad? Not sure how but best bet check at the power inverter to verify it has power then I would diagnose the inverter. I wonder if it has its own fuse?
Some inverters do have a fuse as part of the unit-- have you verified that there is 12 volt power to the inverter --??
#4 ·
I don't know how to check for 12v power to the inverter - I don't know where to find the inverter. I've done some googling and best I have found is it's "under the driver side dash" more or less.
I guess I can have Chevy check it at the next oil change.
