2021 2500HD Denali with 2600 miles. . I can not get the AC power outlets to work, the engine is running. I have a small iPad charger plugged in, I push the button to turn on the outlets, the button lights up steady green, the little green light by the actual outlet doesn't turn on.
I did take it to the dealership a few days ago and when I went to demonstrate it to them, it actually worked. I was shocked. They said ok bye.
Here I am trying to get it to work again and nothing will power from either the cab or bed outlets, even though the button light is solid green and the engine is running. The green light on the outlet will not turn on. It's a small load, maybe 5-10 watts so it's definitely not overloaded. I've tried several different items in the outlet and same result.
What am I missing here?
