Technical Service Bulletin PIT5374
From the TSB:
Technical Service Bulletin PIT5374 ........
Here is some of the wording of the TSB for applicable build dates, although there is more detailing part numbers of the new bulbs and labor hours to be used for the work. Warranty may or may not be covered, depending on the status of your original 3/36 OEM warranty. Talk to your service manager ....
For vehicles built before 12/23/14 at Flint Assembly (11th Vin Digit "F"), 1/13/15 at Silao Assembly (11th Vin Digit "G") or 1/16/15 at Ft. Wayne Assembly (11th Vin Digit "Z"), reprogram the BCM with the latest calibration available in TIS2WEB starting on 1/12/2015. The new BCM calibration will increase the voltage to the headlight bulbs in both the low beam and high beam selections.Important: All vehicles built after the above dates already have the new BCM calibrations and the BCM reprogramming does NOT need to be performed.
New Bulbs are also part of the TSB, made by Vosla.
3/5/15 UPDATE: This Update ONLY APPLIES TO GMC's.
Copy of the TSB can be found here:
TSB Here
Lengthy discussion here: Headlight Illumination Issues - 2014/2015 Silverado & Sierra Issues, Troubleshooting, & Recalls/Service Bulletins - GM-Trucks.com
From the TSB:
TSB Here
