2017 Silverado HD large inverter (3kw) install
51K views 74 replies 15 participants last post by  jdwarren
#1 · (Edited)
I didn't see too much detailed information on installing a large inverter in one of these trucks, so I rolled the dice and just went about it the best way I could determine. I think it turned out reasonably well. It's not the cleanest install imaginable, but it's easily removed for vehicle trade-in or sale purposes. Note that I did this install late last year, and have since driven over 5,000 miles with absolutely zero electrical issues, so I think it's a sound installation.
I chose the AIMS 3kw inverter-charger because AIMS is a well-reputed manufacturer of this sort of equipment, and I wanted the charging capability because I am considering building a large power pack for my camper, and I wanted to get familiar with how these things function. Better to spend an additional $300 now then blow it on a $3,000 inverter later. However, for most vehicle inverter applications, the charging isn't really necessary unless you want to be able to run your vehicle's accessories off AC.
I also wanted auxiliary outlets in the truck bed, so I made sure I chose an inverter with hardwire terminals. In retrospect, I should have put the outlets and inlet closer to the tailgate so they could be accessed easily without climbing into the bed. I could move them, but I'd have to either run new wire to the inverter or install a junction box somewhere to make the connection because the existing wire isn't long enough.
The bed outlets are a standard 20A GFCI outlet and a NEMA L5-30R. I chose the latter to make this installation mirror what you'd find on a 3kw generator. For my RV I have an L5-30 > TT-30 adapter, and a TT-30 > 14-50 adapter, so I can connect my 50-amp plug to the inverter via the bed outlet and utilize the full 3kw (the draw on the 20A outlets should not exceed 2.4 kw). You could just as easily use a TT-30 outlet, though, if your only application is an RV.
Now, for the numbers. My truck has dual alternators, 220A and 150A, for a combined maximum output of 370A. I also had the high-idle software added to my truck by the dealer so I can raise the idle speed to about 1200RPM via the cruise control button, which would be a good idea if a large continuous load is to be placed on the charging system at idle. 370A * 12V = 4.4kw, so 3kw should be well within the system's capabilities, although I admit to being unfamiliar with the magnitude of thermal losses due to the DC/AC conversion. 3kw / 12V = 250A, so I needed cable/terminals/fuses that could handle this huge current. The 4/0 welding cable is actually right around its limit at that amperage, but it's readily available (as are terminals, fuses, etc.) so I decided it was the best solution. 3kw/120V = 25A, so I went with 10-gauge SOOW (flexible) cable for the AC connection to the auxiliary outlets and inlet. This cable can handle about 30 amps for non-continuous loads or 24 amps for a continuous load (80% of intermittent load capacity), which is close enough to the theoretical maximum 25A that I can draw from the inverter continuously. More cautious types could go with 8-gauge.
I thought long and hard about where to locate the inverter. Putting it in the bed would totally eliminate the issue of routing cables into the cab, but the inverter would then be exposed to the elements without constructing some elaborate (and space-consuming) enclosure. I decided to play it safe and located it under the rear passenger-side seat. The particular inverter I chose is very tall, and I was just barely able to install it such that it does not interfere with the seat or the foot room in front of it. It is not the most aesthetically pleasing location but hey, it's a truck. Also, this inverter's ventilation holes are on its sides, so I don't think the fact that the top of it is covered is a problem. I knew I would have to drill a hole somewhere, and I wanted it to be easily concealable, so I did it in the back of the cab below the rear seat. I used a hole saw and installed a 2-1/4" clamp connector to protect the cables; note that the one I linked to above is only 2" (can't seem to find the 2-1/4" on Home Depot's website). It was extremely difficult routing the cables through the connector; if I were to do it again, I would go with two smaller holes and clamps. I was able to screw the clamp down on the cables enough that I didn't feel like I had to use any sealant, but I guess you could use silicone or something to totally eliminate the air gap.
Some of you may be wondering about the dedicated neutral wire. For the amount of current that this system needs to be able to handle, I did not want to roll the dice on the resistance across all the body/frame/engine/alternator connections, especially since many of these connections are exposed to the elements and may be subject to increasing resistance through time due to corrosion, dirt, rock salt, etc. The other thing that may be odd-looking is the bond I installed between the two alternators' positive terminals. I did a continuity test from one alternator to the other with the truck in its original configuration and found that there's no resistance between the two (it's one continuous system), but I realized that the current path from one alternator to the other routes through small (relatively speaking) 2-gauge cables to each battery and then to the starter. So if I made the connection to only one alternator, the current path from the other alternator to the inverter connection would be alternator 2 > battery > starter > battery > alternator 1, all through those smaller cables which have no overcurrent protection and could become very hot if I were drawing a full 3kw from the inverter. Plus, the voltage drop could make the system unable to provide the full 3kw at all. Therefore, I bonded them together with a small length of the welding cable.
Aside from the hole I had to drill in the cab, the only really annoying part of the installation was routing the huge cables out of the engine bay. I had to remove the passenger-side battery to install the fuse block anyway, so while I was in there I pushed the cables through a small gap between the sheet metal that constitutes the fender. I then removed the wheel well shroud from outside (it's held in by little Torx screws) and was able to route the cables on the inside of this shroud down to the back of the passenger side front wheel well and have them pop out right next to the frame rail. From there I routed them over the running board anchors and secured them with zip-ties. I covered the exposed positive cable with wire loom as an extra added protection against the possibility of the insulation being compromised from road debris or some unforeseeable catastrophe. To secure the inverter to the floor I just used two 2-1/2" self-tapping hex-head screws from Home Depot and drilled right through the carpet and into the metal floor below (after checking under the cab about a dozen times to make sure I wasn't going to hit anything).
The install works about as well as I could have hoped. I am able to run a pair of 1500-watt space heaters off it simultaneously. I don't even have to use the high idle; as soon as the truck's electrical system detects the voltage drop (at that load, the alternators can't supply the needed current at idle so the batteries begin to deplete) it increases the RPM on its own. One thing I have not yet tested is starting my 15k BTU/hr air conditioner, which is an important test because the space heaters are resistive (as opposed to inductive, like the AC's compressor) loads and, as such, their starting current is no higher than their running current. Update: the inverter has no problem starting and running my 15k BTU/hr air conditioner, even while simultaneously powering my 1200-watt water heater, DC power converter, and refrigerator.
I may have forgotten some details, so if you have any questions feel free to ask. Rather than answer in a reply, however, I'll probably just add the relevant information to this initial post so that anyone reading this in the future will be able to find all of the info in one place.
Edit 1: A note on circuit breakers and fuses. I tried a 300A circuit breaker and it tripped under a load that I estimate to be about 230A. At that point I decided to go the simpler route of a fuse and block, and just deal with replacing the fuse in the (extremely unlikely) event that I ever blow one. Breakers can degrade over time, and my understanding is that they're designed to "fail safe," so they'll trip at lower, rather than higher currents than their rated capacity. I don't have detailed or technical knowledge of circuit breakers, so it would be interesting to hear others' experiences in this area.
Edit 2: For reference, the length of my cables (neutral and hot) is about 20 feet, for a total length of 40 feet from the hot side of the alternator to the inverter and back to the neutral side. Less is always better, as wire has finite resistance. Remember, P = (I^2)*R (where P=power [watts], I=current [amps], and R=resistance [ohms]). This means that your power loss due to a given resistance is going to be much greater if that resistance is on the 12 VDC side as opposed to the 120 VAC side. How much greater? Well, for a given value of P and R, the current on the 12 VDC side (upstream of the inverter) will be 10 times greater than the current on the 120 VAC side (downstream of the inverter). 10^2 == 100, therefore the heat (or power) dissipated across the same value of R (assuming a corresponding impedance on the 120 VAC side) will be one hundred times greater. Coupling this with the understanding that the cable or wire used to transmit the power has its own resistivity (resistance per unit length), it's easy to see why you're always better off locating the inverter as close to the DC voltage source as possible in order to minimize the length of cable that the low-voltage DC current has to flow through. You can always just use extension cords or hardwire some auxiliary outlets on the 120 VAC side. This is a much better solution than locating the inverter far away from the alternator(s).
Edit 3: If you are going to install something like this, I recommend doing a "bench test," in which you wire up your inverter with the correct-length cables, fuse block and/or breaker and anything else and load it under your worst-case scenario conditions, but before actually drilling any holes or routing cables. A poster below proposed the use of bulkhead connections instead of drilling a large hole in the cab; if you do this, make sure those bulkhead connections are used in your bench test, as those connections have finite resistance. Also, do not use bulkhead connections for any 120 VAC circuits! Doing so poses a major electrocution hazard.
Edit 3A: There is a discussion about the safety of using bulkhead conductors for 120 VAC somewhere between posts 10 and 20 of this thread. I maintain my recommendation -- in the strongest possible terms -- against doing this, but if you have a strong fundamental understanding of electromagnetism you may be capable of doing the requisite analysis to safely deviate from standard practices and implement this design.
Edit 3B: I've done some more thinking about the use of bulkhead conductors for 120 VAC circuits. I still think it's a bad idea, but it's not necessarily suicidal/homicidal provided that you are using GFCI for all your circuits and the inverter's ground terminal on the AC side is bonded to the vehicle chassis. This gets a lot more complicated if you are using an inverter-charger that may be connected to shore power, because you need to make sure that your inverter has an internal relay that breaks the chassis-neutral bonding when shore power is supplied. If it doesn't, then an open neutral connection on the shore power side could result in the vehicle chassis being energized at line voltage. In that scenario, if the inverter circuit is not GFCI-protected, you're basically asking for someone to be electrocuted. If what you just read doesn't make perfect sense, just drill the damn holes for your 120 VAC cables and insulation. ;)
Edit 4: A note on AC cable/wire selection. You could use Romex for the auxiliary connections, but solid-core cabling like Romex needs to be secured such that it's never really subjected to any kind of physical movement. The one advantage (aside from cost) to using Romex is that it's easy to connect to hardwire terminals. What I wound up doing was using outdoor-rated flexible SOOW cable, and then inside the auxiliary outlet and power inlet gangboxes I connected the SOOW to the outlets/inlets using a very short (three inches or so) length of 10/2 Romex and wire nuts. I did this because the stranded SOOW cable is difficult to insert into the hardwire terminals on the outlets/inlets. The gangboxes got pretty crowded, though. You could skip this and tie the SOOW in directly, but you need to be extremely careful about individual strands of the wire not seating fully and remaining exposed, as this nearly guarantees a ground fault (electrocution hazard!) or short circuit.
Edit 5: You will need serious cable cutters to cut 4/0 effectively and without creating a mess. The cutters I link to below will work, but something larger would probably be better. For stripping insulation I just used a sharp box cutter and was very careful not to cut any of the strands.
Edit 6: Here is a handy voltage drop calculator. My parameters are:
Wire Material: Copper
Wire Size: 4/0 AWG
Voltage: 14 (approximate alternator voltage)
Phase: DC
Number of conductors: single set of conductors
Distance: 20 feet (it specifies one-way distance, not round-trip)
Load Current: 250A
I get a voltage drop of 0.49V, which sounds about right as compared to my practical measurements. You can measure voltage drop at a specific inverter load by measuring V_alternator - V_inverter. V_alternator is the voltage measured across the alternator's positive terminal and its metal housing. V_inverter is the voltage measured across the inverter's positive and negative terminals. Both measurements need to be taken while the inverter is under load; i.e., the values will be different for different loads. Do this during your bench test. If your voltage drop is significantly greater than what the calculator predicts, take a look at your connections and any other resistive devices in the current path (fuse/block, bulkhead conductors, etc.) and see how bypassing them affects the drop. Of course, you can't bypass the fuse/block for the full install, but if you find that it's adding significant resistance you will realize ahead of time that there's some debris or other issue that needs to be addressed before you go any further; these issues are much easier to diagnose with all the wiring and other hardware exposed than post-install. Remember, if V_inverter drops below some specified cutoff voltage (probably 10.5 V), the inverter will shut itself off. And don't forget that resistance under load means heat dissipation, at a rate of I^2*R.
Below are links to some of the hardware I used for the install:
AIMS 3kw inverter-charger: https://www.amazon.com/gp/product/B00NZCRFRQ/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
16-ton hydraulic crimper (the 10-ton is not large enough for the terminals I used): https://www.amazon.com/gp/product/B00GXQ2E5E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
ANL fuse block: https://www.amazon.com/gp/product/B000K2K7TW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
300A ANL fuses: https://www.ebay.com/itm/300A-AMP-A...ted-High-Quality-Fuses-6-Pack-Car-Audio-Blade-/173191129908?hash=item2852feeb34
4/0 terminals: https://www.amazon.com/gp/product/B00030CYU6/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
4/0 flexible welding cable (black): https://www.amazon.com/gp/product/B00KD27670/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
4/0 flexible welding cable (red): https://www.amazon.com/Gauge-Premiu...F3T2BK5B12QHTF0Z&pd_rd_w=CI1XU&pd_rd_wg=igc4s&psc=1&refRID=EBQAF3T2BK5B12QHTF0Z
Heat shrink (red): https://www.amazon.com/gp/product/B01F2LG3JS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Heat shrink (black): https://www.amazon.com/gp/product/B01F2LGF5U/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
3/4" wire loom (red): https://www.amazon.com/gp/product/B00TE1SCQU/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1
10/3 SOOW cord: https://www.homedepot.com/p/Southwi...oot-10-3-600-Volt-CU-Black-Flexible-Portable-Power-SOOW-Cord-55809799/204632922
15-amp power inlet (outdoor rated): https://www.gordonelectricsupply.co...BRBMEiwAmKSB8yYhMgcbfabQHNAQbLEU_3qj2oGwrS3G3vLhgB7sYfZ0Zmsd5hn4CRoCJMkQAvD_BwE
2-inch clamp connector (EXAMPLE -- see discussion above): https://www.homedepot.com/p/Halex-2...om/p/Halex-2-in-Non-Metallic-NM-Sheathed-Cable-Clamp-Connectors-05120/100127021
Cable cutters: https://www.homedepot.com/p/Pro-sKi...etj85Y1zKRneqqgkiAhkz4-2oOwdZrQNAaAgrvEALw_wcB&dclid=CIHVwZW8gNoCFYS9swodiUcOgQ
Update: The install looks a lot cleaner with these Maxliner floor mats covering the cables routed under the back seat.
UPDATE: I've since relocated the in-bed inlet/outlet to make room for my auxiliary fuel tank. This has the added benefit of making the inlet/outlet accessible while standing behind the tailgate. I definitely should have done it this way from the outset.
#48 ·
I dunno man, I'd think I'd prefer a 300A fuse to blow before testing exactly how much current two batteries and 4/0 cable can source. That kind of power can easily start a fire as you can see how hot the stuff got.
#49 ·
Yeah, I'd have to do some further analysis before I'd recommend foregoing the fuse. In any case I'm going to keep an eye on the fuse holder and check the torque on the studs regularly going forward.
#51 ·
This is a great thread and thanks for all the information, I have learned a lot reading through this.
Here's my problem and my ideas of how to handle it. Please give me more ideas or thoughts.
2017 Duramax 2500. My truck barely heats up enough to run the heater at the end of my commute in the winter (I live in Montana). I would like an inverter large enough to run a space heater (2000W?) to make my commute a little warmer. I'm sure I would be able to use a larger inverter for other things too.
My rear seat is full with one of those du-ha bins. I'm thinking about not mounting it but keeping it under the passenger seat. Then having the wire come under the dash somewhere so I can plug it in when I want to use it using something like this:
TOPDC Jumper Cables with Quick Connect Plug 1 Gauge 25 Feet -40℉ to 167℉ 800Amp Clamps Heavy Duty Booster Cables with Carry Bag (1AWG x 25Ft) https://www.amazon.com/dp/B078NSKCL...p/B078NSKCLZ/ref=cm_sw_r_cp_apa_glt_i_ZTMZQXWH459FFTWNNP6K?_encoding=UTF8&psc=1
So the questions I have:
1. Can this work with a plug? Or is there too much resistance in the plug to run an inverter?
2. I'm hoping to find a hole in the firewall to route my cables. Would I be able to do it this way?
Thanks for any help you can give me.
#53 ·
1) I don't see why it couldn't work with a plug, but at 2000 watts you're looking at over 150A continuous. I would use 2/0 AWG minimum for that; 1 AWG is way too small in my opinion. The 800A claim on those cables you linked is for an extremely short-duration load and the voltage drop at that amperage would be enormous.
2) Realistically you're not likely to find two existing holes (I recommend running a dedicated ground) for 2/0 AWG wire. You will probably need to drill new ones and put a waterproof cable gland in each.
Some additional thoughts:
Wouldn't it be easier, simpler, and more effective to just install a remote start so you can start the truck earlier and warm it up before you leave? That would also be better for the powertrain than running it cold right out of the gate.
I strongly discourage having an inverter of this size in the truck without mounting it. Too many opportunities for short circuits, loose lug connections, etc.
What kind of space heater pulls 2kw? Standard space heaters are generally 1500w, and the reason for that is so that they only pull 12A on a 15A 120VAC circuit (heaters are considered continuous loads; wire ampacities are for intermittent loads so 14 AWG wire which is the typical requirement for a 15A, 120VAC circuit can only handle 12A continuous).
Your charging system is rated based on an assumed RPM, and if your engine is below that speed the ampacity has to be adjusted accordingly. If your truck is in "park" the ECU is smart enough to detect voltage drop and speed up the engine accordingly to sustain the load, but as soon as you put it in "drive" this logic is disabled so it doesn't apply acceleration while you're sitting at a red light with your foot on the brake. The result is that the load can start to draw down the truck's batteries and eventually you'll hit the low-voltage cutoff on the inverter (usually around 10.5V). 1.5kw from a purely resistive load (so there's no reactive power to be dissipated) is probably okay but it's something you should be aware of.
Make sure you do some calculations on the wattage of the heater before going down a long and expensive road. 1500w may seem like a lot but cars and truck cabs aren't insulated like buildings and you may find that the heat loss through the windows and so forth is such that the 1500w from the heater may not make that much of a difference. Consider the power consumption of automotive air conditioning compressors. Note that this is just the power consumption; the actual heat rejection is likely quite a bit more than these numbers (and it's the heat rejection, not the power consumption, from an air conditioner that's comparable to the heat addition from a heater in terms of perceived change in temperature).
#52 ·
Have you looked into the pre heaters? I know there are a few diesel powered heaters that tap into one of the coolant lines to provide "quick" heat for people who do short runs.
Also, I have found that the truck will get cab heat faster if once you break about 110F, come to a complete stop, then do a WOT acceleration up to about 60mph 2-3X. Water cooling the turbo will heat the entire system quickly.
If you look there are also 120V versions, but you will need power to make those work.
#54 ·
I agree with the above. What ever you do you need to mount it solidly. If you want to have it removable then I would suggest wing nuts or even carry a 3/8 inch impact driver to remove regular nuts. I don't think an electrical connector is a good idea. Even a small bit of corrosion could lead to something that looks like post # 47 in this thread and it would be inside your truck. There are lots of trucks for sale on the auction sites that had cab fires. Yours could be one of them. I would look really hard for a location on the outside of the truck to mount the whole thing. I'm thinking there would be room between the truck bed side and the wheel well, opposite where most people put lift pumps. On my LMM there is also a place under the driver's side of the cab that would work except I suspect that there is a lot of engine heat there.
Something to consider is the ability for the electrical system in the cold. The engine takes a lot more amps to crank when it is cold out so it runs the batteries down more. The batteries have a significantly reduced capacity when they are cold. A battery that is below 32 degrees won't charge at all until it warms up a bit. The current going through it does the warming before it does any charging. The charging system is designed to just meet these conditions in the stock situation unless you have one of the upgrades. There is certainly not enough to power a 1500 W heater all of the time. If your commute is so short that the engine doesn't warm up on the way then I suspect the batteries wouldn't get warm enough to charge much, even without a big load.
If you have a single alternator it is probably capable of 150 A at best, a bit less at lower RPMs. Hopefully you are not winding out your cold engine to get the alternator to put out it's max capacity. If you have the right RPO code you may have a 220 A alternator and if you have dual alternators you could have both ratings. Let's suppose you have 150 A. At 13 volts that would be 1950 watts. However, that isn't all available to be used as a space heater. It takes about half of that to run the truck with the headlights on and a few other accessories. At a minimum you would need the 220A alternator to even have a chance. In reality, the dual alternator setup would be a good idea.
I think a 1000W hair dryer would be about all you could reasonably power but that could be a big help, especially to defog the windshield. You can get 12 volt hair dryers but they are limited to about 250W and would need 20A wiring, which your truck has. Depending on the cab layout, you should have a cigarette lighter and aux power outlet in the dash. They are 20A each. The center console may have one or two and the back seat may also have one or two. Combined they are another 20A. The fuse for the cigarette lighter is under the hood. The others are in the dash fuse box. You would need to remove the fuses and see which socket died to be sure of what goes to what but you could come up with 700 watts or so that way and it would be cheep, relatively speaking.
I don't like the thought of driving around with a space heater in the truck. Unless it too is well attached it will set the place on fire.
You can get a timer from any hardware store that will turn things on at a particular time. These are intended for use with a water heater so running a small space heater should be no problem.
Plug your engine block heater into this and when you go out in the morning the engine will think it is summer. If you also mount a small battery charger in the truck and plug that into the same timer than the batteries will also think it is summer and will be topped up. I'm not a big fan of starting an engine and letting it idle for extended periods because that is hard on it but a remote start 15 minutes before departure would have the engine and interior ready to go without much additional wear on the truck.
Unless you can plug in at work, this won't work for the drive home.
How about this?
Bolted down of course. You could bolt it to a large board and set it on the passenger side floor, tucked in under the seat and propped under the dash. You could slide the seat back to remove/install it. Slide the seat forward to secure it in place. You could mount a tank in the bed and run a hose through your split rear window. What you don't have a split rear window? What a problem you are. Use one of these to refill small tanks from a 5 gallon tank.
#56 ·
How about this?
I agree this is a good solution to the heating issue but if ran long enough it could displace the air with CO2. I'm not smart enough to know if it would meet the threshold of creating a problem but venting it would remove the heat. Additionally, it will create moisture which will only worsen the window fogging issue.
After all that... you have a gas-fired appliance in your enclosed vehicle. If you're okay with it... good. But could this cause any problems elsewhere (i.e. someone at work sees you light this thing up and complains to da boss)?
#62 ·
I have, and it works fine as long as long as I'm in park (in park, ECU will speed up the idle to overcome voltage drop) or moving with the RPMs above 1200 or so. If you're crawling in traffic the OEM charging system can't really keep up; I think it may be due to the non-unity power factor of the AC, because comparable (or higher) wattage resistive loads don't cause these disturbances (I was routinely running my 1200w electric water heater, 800w clothes dryer, 300w fridge, etc. and never noticed any issues even at low speeds).
The only time I run the AC while moving is to make sure the trailer doesn't get to lethal temperatures on hot days because my pets ride in the trailer. The amount of heat conduction to the ambient air at 70 mph is enormous so even with an AC cranking away it's not going to be chilly in there when you stop, but it should stay cool enough that there's no hazard to pets (and we also have a remote temperature readout and a camera system to keep an eye on them -- yeah we're weird and paranoid).
#65 ·
Besides, it probably says on the box not to use it in an enclosed space and only to use it with adequate ventilation. If you can't have the window cracked or the heater on a bit then it probably isn't a good idea.
There is such a thing as a 120V alternator too. You could do a dual alternator setup with one of the alternators being 120V. It would be dedicated to running the heater. The frequency would be way off and it would be DC but a radiant heater wouldn't care. Much less hassle, cheaper and smaller wires too.
#67 ·
Lol, looks like someone wants a belly scratch.
Here's our little buddy visiting Rocky Mountain National Park a couple years back...
#68 ·
#69 ·
And since I mentioned the kittens I know everyone is waiting for a pic of them too. I will not disappoint. Here's the whole crew somewhere in Montana.
I'm proud to have successfully transitioned this truck inverter install thread to a cat picture venue.
#70 ·
Lol, looks like a happy fur family there! Meow!
Ah, it's all fine, it's your thread, do as you please. 🤪
#74 · (Edited)
JD our male took almost a year to get sociable with the kitten. Still not like it was with the previous female that we got at the same time as him. Getting better though. It takes a long time for cats to get sociable with each other from my experience. Be patient, she might get there. And the older they are, the longer they take.
Reactions: jdwarren
#75 ·
JD our make took almost a year to get sociable with the kitten. Still not like it was with the previous female that we got at the same time as him. Getting better though. It takes a long time for cats to get sociable with each other from my experience. Be patient, she might get there. And the older they are, the longer they take.
Well, it's been 3.5 years, so hope is fading...LOL
