2018 L5P intermittently losing power for 10-20 seconds and then back to normal
23K views 21 replies 8 participants last post by  zamoradaniel45
#1 · (Edited)
So first off No Lights or codes! I have 2018 L5P 3500 GMC Sierra Crew Cab non dually. Manufacture date 10/17. I can either pull out from a stop or be going down the road when accelerating and if feels like I am having transmission issues shifting into the next gear and then all of a sudden the power is back and I take off like a rocket. All the trans service has been kept up with and no issues. What I did...I took it to the dealer they told me to change the fuel filter which I did no issues there. They went on to say with no lights or codes I would be chasing a ghost they are more than willing charge $130.00 just to hook it up to the computer and labor after that. They told me its not the transmission! So I bought a Banks Data Monster I dash. Plugged it into my OBDII port and the data started flowing! I noticed when I have the reduced power / shifting issue the Fuel Rail Pressure Commanded is 27,500psi however the Fuel Rail Pressure actual is 3,577psi. During times of normal operation there is a difference in these two numbers of +/- 1000psi and as low as 100psi. I'm wondering what my next step is. Replace the fuel pressure regulator sensor? Is there something I'm overlooking that is glaring or common? Oh and my lift pump for the tank is pretty consistant with a psi range in the sixties so I dont think that's it!
My understanding is that fuel pressure regulator sensor limits the flow from the fuel pump can push into the fuel rail. Seeing the sensor is cheaper than the pump I wanted to start with the sensor.
Any thoughts or assistance is greatly appreciated. Thank you!
The FPR is the fuel pressure regulator which is mounted on the fuel pump.The FPR is a solenoid which regulates pressure going into the fuel rail. If the FPR is unplugged, there is no regulation of fuel pressure sent to the fuel rail. The FRPS is the Fuel Rail Pressure Senso, determines actual fuel rail pressure of course, and is mounted on the fuel rail. Pressure information from the FRPS is sent to the ECM and the ECM sends signals to the FPR telling it what pressure to allow into the fuel rail based on a host of different pieces of information like temperature, boost, throttle position, etc.
So It looks like the ECM is commanding the FPR to regulate to 27.5k but the rail is at 3.577k. The job now is to figure out where the problem is. There is another post recently with very similar symptoms so look for that post and see what information you can develop.
Just my take on it.
There was an issue with the FPR connector on some trucks. There's a TSB somewhere on the forums. It would usually throw a code, but I guess it's possible to not put out a code. I purchased the spare connector just in case. Let me see what I can find.
#11 ·
Your P228C code is listed in the document. Based on everything you've described, you more than likely need to replace your FPR connector.
#14 ·
Ok, let's try a direct PDF attachment...
#15 ·
@timothy.morris17078
Ok, that worked. While I make no guarantees, I think you'll find some answers in the document above.
#16 ·
You sir were 100% right. The connected didn't need to be replaced. However I unplugged the connector looked at it a little light cleaning because it looked really good but plugged it back in and the problem is gone!!!!!!!!!!!! Thank you for the assistance! This was a really annoying problem that really was driving me nuts! Thanks again!
#17 ·
You're welcome, if it comes back though, you're probably going to have to replace it. It seems to be a common problem. I vaguely remember that the new connector is a slightly different style.
My replacement connector is already sitting in my pile of spare parts...
#18 ·
@viper8315 I am having the exact same issues this thread is talking about (watching fuel rail pressure drop from 27k to 3k). Just to confirm before I start tearing into this, Is this the sensor and connector that is directly on the passenger side fuel rail?
#22 ·
You're welcome, if it comes back though, you're probably going to have to replace it. It seems to be a common problem. I vaguely remember that the new connector is a slightly different style. My replacement connector is already sitting in my pile of spare parts...
Do you happen to have part number on that FPR connector?
