I had originally posted in the 911 forum, but seems this may be a better place..
I purchased a 2020 Sierra 2500 Duramax a couple of years ago. It was hit very hard in the front just right of center on the crankshaft. It busted the front cover, pulleys, etc. Broke the fuel pump housing. Was hit hard enough in the front to bend the rear leaf springs. It ended up needing a frame. its all back together and painted.
I drove it about 10 miles on the interstate about a month ago. It felt decent. Maybe lacking in power just a little bit, but I also didn't get in to it much. Came home to finish things up and clean it up.
It quit running on me in the driveway. After a few days trouble shooting it, I found that the LAN system wasn't letting all the modules talk to each other. The glow plug module I think was the culprit. Fired right up after plugging everything back in.
Drove it to lunch, again on the interstate. When I exited, it was running pretty bad. Got worse when I got to the parking lot. It did fire up to drive home, but quit on my about 5 miles later. Towed it home and has been the same condition every since.
I have a P0016 code showing the cam sensor and crank sensor aren't liking each other. Both of those sensors are new. The camshaft gear and reluctor ring are also new. I would say that I am quite certain that the marks are lined up. I have built many engines in my time and have never had cam timing off.
I can see I have about 8500psi on the high side of the fuel rail. That seems to be double what it should at idle. I can try to increase rpm, it will climb to about 1200 then fall off and die. I have just completed checking all of the hard lines and the return lines for any kinks or restrictions. I even replaced the left fuel rail with fuel pressure regulator #2 and have no change.
Low side fuel pressure is right at 60psi. I can kill each injector and the engine will die... With the exception of #6 and #8. The truck has 40,000 miles on it. It did sit for two years, but the fuel system was all together. I did fire it up with the old diesel fuel in it. The filter is completely clean. I can blow air through all of the return lines ands back to the fuel tank.
I also have pretty low oil pressure. Fires up around 60psi. Once warm, falls off to around 7-8psi. I thought this was due to the over fueling and fuel in the oil, but I just changed it and still the same thing as soon as its warmed up.
What can I check? Would two dead fuel injectors be causing all of this? Are the simple enough to swap with other cylinders to see if the problem follows the injector or stays with the cylinder?
Pleas help. This thing is driving me crazy and id like to drive it.
