Calling @JimmyD, @blythkd1, @sambor and any other towing gurus...
I've had it with the ITBC. Last night while pulling my enclosed trailer I got the dreaded "service trailer brake system" and pulled over. I plugged in my trailer brake controller testing unit and got the same message. I pulled out my Bluedriver, read/cleared all the DTCs, and everything worked fine after that. It was obvious that after the initial error message that the trailer brakes simply stopped working entirely while driving. This is completely unacceptable; the controller should blindly apply voltage regardless of the resistance values or anything else to at least give you SOME CHANCE of getting braking force. The thought that some kind of software glitch or DTC in system memory could cost me and my family our lives is just as infuriating as it is terrifying.
Anyway, I'm done with this GM-junk with firmware written by retards. Time to go aftermarket. Has anyone wired up an aftermarket brake controller in one of these trucks? Any thoughts or guidance? I want to completely bypass the entire GM system; I don't even want to use their receptacle or wiring (I intend to add a second receptacle). I want this thing as simple as possible; no relays, switches, plugs or any other garbage like that. Just a home run from the controller to the battery and a single piece of wire going to a new receptacle.
If anyone has any thoughts on brake controllers or ideas for installation/wiring/etc. please let me know. If not...I'll figure it out and post a DIY thread. Thanks.
